Thu, Nov 7, 5:29 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 05 9:36 pm)
Subject: Occlusion Master and Unimesh realism Kit Problem in Smith Micro Poser7
Lenora2 ( ) posted Fri, 25 July 2008 at 8:27 PM · edited Thu, 19 September 2024 at 9:01 AM
I just upgraded my Poser7 to SR3 and, yesterday, while trying to use OclusionMaster in a render I got this error in the script screen:
Traceback (most recent call last):
  File "D:E frontierPoser 7RuntimePythonposerScriptsWacrosUserDefinedOcclusionMaster.py", line 338, in ?
    MatDlg = MaterialsDlg(tk)
  File "D:E frontierPoser 7RuntimePythonposerScriptsWacrosUserDefinedOcclusionMaster.py", line 70, in init
    Label(self.HelpFrame, text='HELP', font=f).grid(row=0, col=0,sticky="w")
  File "D:E frontierPoser 7RuntimePythonliblib-tkTkinter.py", line 1790, in grid_configure
    self.tk.call(
_tkinter.TclError: ambiguous option "-col": must be -column, -columnspan, -in, -ipadx, -ipady, -padx, -pady, -row, -rowspan, or -sticky
I tryied changing the script code, bud as looking trough the code I saw everything was as it should be, so I got confused...
UnimeshRealismkit is also doing a similar error:
  File "D:E frontierPoser 7RuntimePythonposerScriptsWacrosUserDefinedUnimeshRealismKit.py", line 1566, in ?
    SkinShader = SkinShaderDlg(tk)
  File "D:E frontierPoser 7RuntimePythonposerScriptsWacrosUserDefinedUnimeshRealismKit.py", line 1096, in init
    Label(self.StatusFrame, text='Selected Figure  : ').grid(row=0, col=0, sticky="e")
    self.tk.call(
Actually they are kinda the same, but better put more than less info in the post.
I hope someone helps me, Altough I have V4Realism Kit I still use Aiko3 a lot in my renders, and Occlusion Master is already a great tool itself, I don't want to loose them.
Thanks already.
adp001 ( ) posted Fri, 25 July 2008 at 8:33 PM
The newer Python version updates Tkinter. Now each
... .grid(row=0, col=0, sticky="e")
must be changed to:
 ... .grid(row=0, column=0, sticky="e")
Lenora2 ( ) posted Fri, 25 July 2008 at 8:54 PM
Mine is alredy like this
copy of the grid line:
self.ButtonFrame.grid(row=3,column=0,columnspan=3,sticky="ew")
bagginsbill ( ) posted Fri, 25 July 2008 at 9:05 PM · edited Fri, 25 July 2008 at 9:06 PM
No it isn't already like this. Maybe in one place, but that's not the place it is talking about.
Look at the error it is showing you what line exactly:
It says right there, line 1096, col=0
ockham ( ) posted Fri, 25 July 2008 at 9:08 PM
There are typically many lines with row and col.  You'll need to change
all of them.  If you have a good word processor, you should be able
to do a "search and replace all" command, to change all
col=
to
column=
My python page
My ShareCG freebies
Lenora2 ( ) posted Fri, 25 July 2008 at 9:15 PM
well, gona try it out after my actuall render ends... alredy changed the col= to column= with txt viewer, hope it works ^_^'
Santel ( ) posted Fri, 25 July 2008 at 9:35 PM
If you purchased them here, re-download your purchases, I believe the latest have been updated.
Regards...
nruddock ( ) posted Fri, 25 July 2008 at 9:55 PM
Attached Link: http://physicalc-software.com/forum/viewtopic.php?t=137
> Quote - ... I believe the latest have been updated.
Post by the author detailing which scripts have been updated.
