Poser doesn't support "plug in" render engines as such but you can always use an external program to do the rendering for you. Some (in no particular order) are
Cinema 4D with the interposer plugin - gives you access to all the C4d render engines like advanced render and VRay etc
Vue (reads pz3 files directly)
My Freebies
Buy stuff on RedBubble
Don't forget the Poser exports RIB (Renderman Interface Bytestream) files natively to Renderman compliant renderers - PRman, Aqsis, 3Delight, Pixie, Air, et al. You will need a material editor to create / attach materials, though if you're comfortable with cr2 hacking you could code your own shaders and (manually) assign them in the RIB.
Attached Link: http://www.keindesign.de/stefan/poser/poserman.html
I once started working on this one, but haven't touched it in quite a while. If you speak Python you should be able to tweak it to get it up and running with Poser 6 and 3Delight.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hello, I'm new to the forum & new to Poser. I have a couple of questions. (Actually I have a lot but I won't ... )
Does anyone have a link to a public list of Poser plug-ins?
Also, is there an external renderer plug-in for Poser 6 and the 3Delight stand-alone software?
I've seen references to Poser/Renderman plug-ins, but have only found professional-cost items, mostly for Autodesk & Arm&Leg software applications. (I looked at the Houdini site too, and I think I know why he was trying to escape ... )
Is there a less expensive way to move up?
TY
