Sat, Jan 25, 4:26 PM CST
Subject: Wide Angle Shot (12 mm) - Any way to reduce distortion (without postwork)
sangelico ( ) posted Mon, 28 July 2008 at 7:04 PM · edited Tue, 14 January 2025 at 11:36 PM
Well - the title says it all - I've tried various solutions - switching to 35mm and moving back, leveling the camera, but none of these give me the same "view" that I get with the wide angle shot. Is there any other non-postwork solution? I've already messed with panoramic views, but couldn't get the same effect - I want the terrain to remain flat, the trees to remain upright, etc. Thanks for any tips!!
Mazak ( ) posted Tue, 29 July 2008 at 1:31 AM
Two links for panorama tutorials. Maybe its what you need.
www.lynescreations.com/pantut1.htm
www.starbase1.co.uk/TUTORIAL-QTVR.html
Mazak
Google+ Bodo Nittel
sangelico ( ) posted Tue, 29 July 2008 at 6:15 AM
Thanks Mazak - some good tips in those tutorials.
Mazak ( ) posted Tue, 29 July 2008 at 6:30 AM
Here is what I set-up. 12mm is very wide angle and you need some space to get straight vertical lines. After the render I cropped the image.
Mazak
Google+ Bodo Nittel
Mazak ( ) posted Tue, 29 July 2008 at 6:32 AM
And here the cropped Image. Mazak
Google+ Bodo Nittel
chippwalters ( ) posted Tue, 29 July 2008 at 10:32 PM
Wow, great image Mazak!
sangelico ( ) posted Wed, 30 July 2008 at 6:20 AM
Mazak - thanks again for your tips! While I couldn't get this particular image to straighten out and keep all other elements I wanted in the scene, your information will be very useful future projects.
stonemason ( ) posted Wed, 30 July 2008 at 9:26 AM
cool render :)
I think you'll never get rid of that distortion,going that low on a real world camera would give the same effect..you could try using something like Pt-Lens to lessen the effect in post
Cg Society Portfolio
FrankT ( ) posted Wed, 30 July 2008 at 1:15 PM
12mm is heading towards ultrawide angle in 35mm photography terms - that's going to give severe distortion.  It can be mitigated a bit but you'll have a hard job removing it altogether
My Freebies
Buy stuff on RedBubble
timspfd ( ) posted Fri, 01 August 2008 at 12:16 AM
There's also the option of using a regular 35mm and doing a series of renders panning across the scene, then compositing them together in postwork. This wont work for animation of course, but is an option for stills.
jc ( ) posted Wed, 13 August 2008 at 12:01 AM
You can minimize the "distortion" by keeping the camera level. And I think Mazak has the right idea (and a great scene).
I say "distortion", because technically the geometry is not at all distorted (not with a high quality real camera lens either) - it's just not what humans are used to seeing. For example, print the scene out, then wrap it around your head, a few inches away from your eyes. You'll have to turn your head to see it all, but what you can see in one view will have no "distortion".
I have a tutorial on Vue focal length effects.
_jc  'Art Head Start' e-book: Learn digital art skills $19.95
'Art Head Start.com Free chapter, Vue tutorials, models, Web Tutorials Directory.
