Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
May I suggest the Cognito plugin, from DCG:
http://www.digitalcarversguild.com/plugin.php?ProductId=6
Cheers.
Another more simple example, I'll upload the file, so you can see it on your own.
Basically it's 2 chains that are connected at the white and the black objects.
I'll name the objects with their colors, because I think it makes it easier to understand:
Orange = rotating disk with spin modifier
White = parented to orange
Green-Blue-Black = IK-chain
Green = Slider, free in the z-axis, locked in x and y-axis
Blue = parented to Green, Ball joint with only 1 free axis (y)
Black = parented to blue, tracking white - full constraint (it's just there to follow white)
Here is the file:
www.evajoe.homepage.t-online.de/mechanics2.rar
Edit: typo
http://www.sparrowhawke3d.com/Sparrowhawke3DPlugins.html
Some free plugins here that can add to workflow abilities also.
bwtr
I am trying to put together a small animation of some linked mechanical parts but I don't know where to start in terms of the animation tools that should be used.
To start off simple, I want to take a disc (or gear) that rotates and has a vertical shaft attached. The shaft should raise and lower as the disc rotates.
I just need someone to point me in the right direction.
Thanks.
