Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 13 3:34 pm)
Attached Link: http://www.sams3d.com
Hi, we use autocad all the time, but what you want to do is after you are done with your dwg., you have to export it out as a .3ds, then you have to insert it again as a .3ds to autocad, then you have to center it on the axis, 0,0,0 - then you export it out as a .3ds, the reason why 2 exports are because you want it in mesh form. Then you can insert it into Poser as a .3ds or you can get a software called 3D Exporation, you can put import it in there and export as an obj format, or most Pain Programs will let you import a .3ds and export it as an .obj. Any more questions let us know, we got the scoop on Autocad, mixed with Poser, Byrce and most other software. SharenThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Is anyone aware of a program that will convert Autocad .dwg files to Poser .obj formate?
