Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:08 am)
Attached Link: http://www.renderosity.com/mod/freestuff/index.php?section_id=34&page=3
I use the texture filter from SVDL, follow the link above, near the bottem of the page you will see the texture filter python script (**Poser 7 Texture Filtering utility).**Shawn
McCarthy
www.defyallchallenges.com
After you install the python script you can run the script and then >>>
Turn Texture Filtering OFF for the figure.
You could additional try setting the min shading rate to a lower value, by going into the render settings and clicking manual (aquire from auto), and then setting the min shading rate to a value closer to 0 (the default I believe is 1).
The script bsaically goes through all of the materials for the figure and turns off the texture filtering (the default I believe is Quality), and for hte DAZ figures (and texture maps) this causes those seems to appear.
Hope that helps explain it, or provides you with the necessary search terms.
Shawn
McCarthy
You have to run it, not just download it. :)
Seriously, I suppose you meant you ran it, but sometimes people make mistakes with scripts. Go into the material room, select one of the skin material zones, and verify that the Image_Map node showing the color is actually set to Texture Filtering: None. If it is any other value, you will get those mismatches, unless you seriously improve your render settings.
Shawn
McCarthy
