Tue, Nov 19, 12:32 PM CST
Subject: Help... Adaption Threshold? Bucket sizes?
ecccoman ( ) posted Sat, 09 August 2008 at 7:02 AM · edited Fri, 08 November 2024 at 9:26 PM
In Poser 7 I am trying to render a scene.  It is not that complex - 3 figs (2 M3s, 1 A3), few props.
During rendering I am getting this message, "There was a problem during rendering.... reduce rendering memory by.......... raising Adaption Threshold or ... smaller Bucket sizes."
Could not find any reference to Bucket Sized.  Where are these settings???
What is going on here???
Thanks
geep ( ) posted Sat, 09 August 2008 at 7:10 AM · edited Sat, 09 August 2008 at 7:25 AM
*(click on the image to view it full size)*
[menu] "Render" >>> "Render Settings" >>> "Firefly"(tab) >>> "Manual Settings" (button)
"Max bucket size" is second from the bottom.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
ecccoman ( ) posted Sat, 09 August 2008 at 7:45 AM
Thanks, Dr Geep
I reduced the Max Bucket size from 64 to 32.  Is there any rule of thumb with this setting??
Should I also be fiddling with the Adaptive Bucket setting in General Preferences??
Thanks
geep ( ) posted Sat, 09 August 2008 at 8:09 AM · edited Sat, 09 August 2008 at 8:10 AM
Quote - Thanks, Dr Geep
No, just try using the largest value that does not cause an error.
No, not unless you get an error.
One should never "fiddle' with anything that one does not know anything about. 😄
(note to self - must learn how to play the fiddle)
Thanks
You're quite welcome.
Glad to help. ... ;=]
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
ecccoman ( ) posted Sat, 09 August 2008 at 8:21 AM
Uh-Oh
I did fiddle with the Adaptive Memory Size.   I put the Adaption Threshold back to .3750.
But I don't know what the Memory Buffer Limit was set at!!!!!  Can you tell me a value??
Thanks Doc, sorry for all the trouble.
If I ever get past the glitches, I think I could really enjoy this software.
Thanks
IsaoShi ( ) posted Sat, 09 August 2008 at 8:29 AM
The default value is 32MB.
geep ( ) posted Sat, 09 August 2008 at 9:06 AM · edited Sat, 09 August 2008 at 9:07 AM
No problem ecccoman ............... always glad to try and help.  ... ;=]
Thanks **IsaoShi 🆒
**😄 Here's a ......... "Serving Suggestion" ............. 😄
It's always a good idea to write down a value before you change it so you can set it back to the original value if something does not work properly after it's changed.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
