Thu, Jan 23, 12:30 PM CST
Subject: Collections
ghoyle1 ( ) posted Thu, 14 August 2008 at 6:18 AM · edited Sun, 19 January 2025 at 11:26 PM
 just discovered this feature (duh! took me how long since Poser 7 came out???) and I've discovered how to add items to the collection. Great! Looks like it'll be a real blessing.
Now that I've added characters, poses, etc. to a collection, I'm having trouble figuring out how to add those characters, etc. to a scene! I click on them and nothing happens. I click on the checkmark at the bottom, nothing happens. Is this normal? Am I missing a trick? Any advice would be welcomed.
Thanks in advance,
Guy Hoyle
IsaoShi ( ) posted Thu, 14 August 2008 at 6:56 AM · edited Thu, 14 August 2008 at 7:00 AM
Just a thought... probably a red herring, but worth asking...
Collections items are just references to the actual content in your Runtime libraries.
You haven't moved (or renamed, or re-organised) your Runtime(s) since creating the Collection items, have you? If so, you may have broken the references.
ghoyle1 ( ) posted Thu, 14 August 2008 at 7:13 AM
No, I haven't.. In fact, I just ran a tst by adding 2 figures to a newly created collection, and they don't work, either. Nothing happens when I click or right click. At the bottom of the pallet I see only a single check ("Apply library preset") and a minus sign ("Delete from Library").
Guy
Plutom ( ) posted Thu, 14 August 2008 at 8:43 PM
I think I got it, what I did was load a figure, clothes, and shoes and saved it to figures. Then opened a new screen.  Then click on my model package-everything came up great.  Then I saved it in Pose, made a new screen and tried to extract it --nothing worked just got the delete sign same as what you had.
Bottom line, try loading your stuff in the figures portion, if that doesn't work, try props and so forth.  Jan
SimonWM ( ) posted Fri, 15 August 2008 at 10:08 AM
A warning. All your hard work creating your collections will be lost when you upgrade your computer. Collections are not like runtimes that you can copy them from one hard drive to the other and will still work. I lost all my hard work when I upgraded computers. Since I don't have the same hard drives/folders arrangements my collections don't work in my new computer.
mojoDallas ( ) posted Fri, 15 August 2008 at 10:27 AM
Thanks for the warning.  I have been just creating new categories and having multiple copies of figures rather than use collections.  From the last comment it appears that this is the best approach.
Hardware:  Cyberpower PC,  2 - i7-3970X CPU @3.50 GHz (12 Total Cores), 32 GB RAM, 2 - GeForce GTX 690 $GB Video Cards, 2 - Viewsonic V3D231 23" Monitors
Software: Poser Game Dev, Vue xStream 2014, 3ds Max 2014, Maya 2014, Mudbox 2014, Corel PaintShopPro, Unreal Engine 4, Iron Python
SimonWM ( ) posted Fri, 15 August 2008 at 12:01 PM
Quote - Thanks for the warning.  I have been just creating new categories and having multiple copies of figures rather than use collections.  From the last comment it appears that this is the best approach.
Yes  safest to reorganize your runtimes than using the collections. They should have included an utility to organize the content within the runtime with dependencies automatically instead of something so superficial as the way collections work.
