Fri, Feb 14, 9:42 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 8:48 am)
Subject: limitations
hijend ( ) posted Sat, 16 August 2008 at 10:09 AM · edited Wed, 12 February 2025 at 12:56 AM
**Is there away to make the limitations default?
for example.. if I try to use a dial on Vicki 4 head..    (mouth size)  and I use the dial.. it always goes back a default max.
anyway of making no limitation?**
dorelia ( ) posted Sat, 16 August 2008 at 10:26 AM
Don't know a way that works for all morphs at once, but you can adjust single morphs.
Click the arrow on the right next to the morph you want to change. Choose settings... and adjust the Max Limit.
ockham ( ) posted Sat, 16 August 2008 at 10:32 AM
You can change the Max and Min values easily. Double-click on the parameter itself, then you can see the Max and Min in the panel that pops up.
These changes will not be permanent.  If you want the figure to have
increased max permanently, you'll have to resave the figure under a new name.
My python page
My ShareCG freebies
hijend ( ) posted Sat, 16 August 2008 at 10:45 AM
Ok thank you very much.. greatly appreciated.
