Thu, Jan 23, 4:51 AM CST
Forum Moderators: Staff
Subject: Render Problem
107Cornfields ( ) posted Sun, 17 August 2008 at 11:25 AM · edited Wed, 08 January 2025 at 8:37 AM
In the preview all looks fine
http://img507.imageshack.us/img507/6739/beforery9.jpg
but when I render the scene I get this effect happening
http://img507.imageshack.us/img507/7104/afterhr1.jpg
Can anyone shed any light on this please, the background image is part of the scene. I assume it is being treated as a texture.
Any input is welcome, thank you.
EnglishBob ( ) posted Sun, 17 August 2008 at 12:09 PM
It looks as though you've applied the image to the double-sided square prop. Use the single sided square and all should be well.
The Firefly renderer has trouble rendering double sided polygons. Yes, the square prop is still double sided by default, just as it was in Poser 4. No comment...
Khai ( ) posted Sun, 17 August 2008 at 12:24 PM
Erm Bob?
they fixed the problem in poser 6. with the material for the prop switch Polygons Forward to On and bingo. problem solved.....
