Forum Moderators: RedPhantom
Attached Link: http://home.pb.net/~stevecox/uvmaptut.htm
Make sure you arent saving the map in a distorted reolution. Heres a link to a tutorial for UVMapper. What you should do is map the lower circlet of the crown cylindrically, and map the headpiece with a planar map.First thing you should do is select all and then hit the / key on your keypad a few times. After this, select all and scale it out so it resembles what you know the shape should be. However, you should take what PhilC said to heart. Open the file in whatever program you made the crown in and assign each part a material or give each part a seperate name. Then in UVmapper select by group and move the part you want to have a seerate color. Lastly, check out the link that Blackhearted provided to get more ideas on what to do. This should get you started.
If you did not join or weld the different parts to your crown you should be able to select them in UVmapper by going to the edit menu and select by group. Then edit menu assign to material. I would recommend especially on complex models assigning materials in Poser using the grouping tool. This lets you see the sub object in 3d as opposed to a flattened out mesh in UVmapper. Then go into UVmapper and create your template.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
![file_183456.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_183456.jpg)
Hey all right i need help big time i made a crown and whant to texture it. Now i made the uv map as cylindrical,as you can see it dont leave me as to what piece is which and i cant judge were one part starts and finishes any and all help very much appreciated cheers dolly
