Mon, Nov 25, 12:40 PM CST
Subject: help with uv mapper
dolly ( ) posted Sun, 24 June 2001 at 6:18 AM · edited Mon, 25 November 2024 at 12:26 PM
Hey all right i need help big time i made a crown and whant to texture it. Now i made the uv map as cylindrical,as you can see it dont leave me as to what piece is which and i cant judge were one part starts and finishes any and all help very much appreciated cheers dolly
Blackhearted ( ) posted Sun, 24 June 2001 at 7:35 AM
Attached Link: http://home.pb.net/~stevecox/uvmaptut.htm
Make sure you arent saving the map in a distorted reolution. Heres a link to a tutorial for UVMapper. What you should do is map the lower circlet of the crown cylindrically, and map the headpiece with a planar map.
PhilC ( ) posted Sun, 24 June 2001 at 7:45 AM
If not already done so you may like to give the different areas individual materials or groups. This will make it easier to separate out the parts to map
dolly ( ) posted Sun, 24 June 2001 at 7:49 AM
thanks both but i dont know how
Teyon ( ) posted Sun, 24 June 2001 at 8:27 AM
First thing you should do is select all and then hit the / key on your keypad a few times. After this, select all and scale it out so it resembles what you know the shape should be. However, you should take what PhilC said to heart. Open the file in whatever program you made the crown in and assign each part a material or give each part a seperate name. Then in UVmapper select by group and move the part you want to have a seerate color. Lastly, check out the link that Blackhearted provided to get more ideas on what to do. This should get you started.
Cybermonk ( ) posted Sun, 24 June 2001 at 8:28 AM
If you did not join or weld the different parts to your crown you should be able to select them in UVmapper by going to the edit menu and select by group. Then edit menu assign to material. I would recommend especially on complex models assigning materials in Poser using the grouping tool. This lets you see the sub object in 3d as opposed to a flattened out mesh in UVmapper. Then go into UVmapper and create your template.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
dolly ( ) posted Sun, 24 June 2001 at 8:37 AM
if i move the parts wont that effect the mapthanks dolly
Teyon ( ) posted Sun, 24 June 2001 at 8:38 AM
THe MAP yes the MESH no.
Teyon ( ) posted Sun, 24 June 2001 at 8:42 AM
Hee's a model of a dinosaur like creature. THe parts were seperated in UV Mapper for texturing. It's a Planar map as you'll note. Hope this helps you visualize what we mean
dolly ( ) posted Sun, 24 June 2001 at 9:06 AM
so if i move the map about it will still go to the model ok thanks dolly
Cybermonk ( ) posted Sun, 24 June 2001 at 9:16 AM
Yes you have to save the model in UVmapper once your through creating the template. This applies the new UV coordinates to the model.
Albert Einstein
dolly ( ) posted Sun, 24 June 2001 at 9:23 AM
oh great thanks a lot dolly
Blackhearted ( ) posted Sun, 24 June 2001 at 10:34 AM
You asked about UV Mapping, so I included a link to a very comprehensive tutorial by Steve Cox in my answer to your question. If you would have bothered to check out the site and read the tutorial, all your questions would have been answered.
