Wed, Dec 25, 2:05 PM CST
Subject: Strange hair render
Stan57 ( ) posted Fri, 22 August 2008 at 11:22 AM · edited Wed, 25 December 2024 at 2:21 AM
I an useing the render studio for vue 6 all default setting rendered on superior,1024X768 and the hair is comming out like below. Any suggestions?
Thanks in advance
Stan57
Jack Of All Trades Master Of None
bruno021 ( ) posted Fri, 22 August 2008 at 1:34 PM
Looks like the hair material has reflections applied, can you check? If so, take it back to zero and see if it gets better. I assume this is not dynamic hair, otherwise, the fix is different.
garyandcatherine ( ) posted Sat, 23 August 2008 at 2:26 AM
Well from the postage stamp sized render, it either looks like a: you have reflection added, b: too much highlights, or c: no trans mapping.  It's soooo hard to tell.
-Timberwolf- ( ) posted Sat, 23 August 2008 at 9:05 AM
I know this from Cinema4D .I fix it there in the material manager by changing from "anti 1" to "mip mapping". Maybe you will find something similare in vue.
AboranTouristCouncil ( ) posted Mon, 01 September 2008 at 7:23 AM
I use the settings pretty much as suggested by this site: http://www.phg-art.ch/?lang=en&page=tutorialshow&tutorial=vue6instyle
Really does a good job with Poser Hair
...Insert some witty or thought provoking comment here...
