Tue, Feb 25, 11:45 AM CST
Forum Moderators: RedPhantom
Subject: New PC : Poser 7 element selection is tediously slow. Please help
Lunedust ( ) posted Sat, 23 August 2008 at 9:45 AM · edited Tue, 25 February 2025 at 10:02 AM
I now have a super PC, quad core 3.0Ghz double graphic card ATI Radeon HD 3870 X2, 4 Go Memory and 32bit Vista.
But after installing Poser on it, I have the problem of very very very slow  selection of elements of objects I add in Poser (in the Pose Window) : such as body parts of V3 or V4 for example, it takes ages to select them, really weird !
Say I select a hand for example, it takes about 10-15 seconds, then another 10 before I can modify dials of that hand.
Render times are fine, no problem there, new PC renders a lot faster than my old one.
Any one have an idea ? Perhaps it's because I installed the latest patch ? I didn't try Poser before patching and I hadn't installed the latest patch on older machine.
Thanks in advance
Lunedust
DigitalDreamer ( ) posted Sat, 23 August 2008 at 9:50 AM
I too have seen some slowness in the Pose window - but even worse, by a long way, is the length of time my PC takes to do anything in the Materials room.
I have P7 with SR3
Quad Core, ATI 4870, 4 Gig of RAM, Vista Ultimate 64 bit.
It's getting to the stage where making any changes in the materials room is just not worth it - shame, as with the new VSS, Poser was starting to create some really cool pics.
Khai ( ) posted Sat, 23 August 2008 at 9:54 AM
aah ATI?
have you tried the ATI drivers fix?
edit the poser.ini file located in C:Documents and SettingsApplication DataPoser 7poser.ini and change
PREVIEW_OGL_OBJECT_BBOXPICKING 0
to
PREVIEW_OGL_OBJECT_BBOXPICKING 1
Lunedust ( ) posted Sat, 23 August 2008 at 10:34 AM
Oh thank you so so much :) big hug That did it for me ! Selecting is instantaneous again now !
So once more, thanks for your so effective solution. /me bows, and for answering so quickly :)
A very happy Lunedust.
Gareee ( ) posted Sat, 23 August 2008 at 12:24 PM
Supposedly the ati drivers back in june corrected this issue, so boxpicking no longer had to be used.. wonder is a later driver busted it again?
