Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
For some strange reason, neither of the above methods seems to work anymore. (I'm using C Pro 7.2.)
When I try the CapLock method, the whole door moves along with the manipulator.
When I try the Control key method, the entire view rotates to a new view without doing anything to the manipulator.
I'm stumped!
I have a question. Is the door you are trying to make open a separate mesh? You say you are
"trying to create a morph target in an existing mesh of a room with a door that doesn't open" If the door isn't a separate object group than none of the advice they have given you will work. You would have to cut the door out of the room mesh in order to open it. Sorry if this is already obvious to you. Just trying to cover all the basses in order to solve the problem.
I'm trying to create a morph target in an existing mesh of a room with a door that doesn't open. I've selected the door polygons and want to rotate them to create a morph that opens the door. However, the manipulator is at the center of the door so it rotates from the center of the door, not the edge. Is there a way I can make it rotate from the edge?
Thanks!
