Thu, Nov 28, 3:59 PM CST
Subject: problems with AO and transparency
ice-boy ( ) posted Sat, 30 August 2008 at 4:35 PM · edited Thu, 28 November 2024 at 3:56 PM
i am using transparency on apollo boots.
when using AO i get this
it is the same if using AO in the material room or on the light.
IsaoShi ( ) posted Sat, 30 August 2008 at 5:47 PM · edited Sat, 30 August 2008 at 5:47 PM
I have also found that transparency maps cause this. The transparent parts of the material are not invisible to raytracing, and cause AO on nearby surfaces - see attached example, this is Rhiannon's Elsa Wylde with part of her skirts transparent.
The only way I found to get rid of it is to make the item invisible to raytracing. Trouble is, it then completely disappears in reflections.
richardson ( ) posted Sat, 30 August 2008 at 5:56 PM
I second this little quirk with the AO on Transparent mesh. Forgot to send it to Tech last time (P6)
Ice-boy,
Did you make sure Trans edge and falloff  were set to 0.00 in matroom? This should get rid of the black...
ice-boy ( ) posted Sun, 31 August 2008 at 1:27 AM
yes i did.
yes i guess the problem is that the mesh is not invisible to AO.
to bad.
bagginsbill ( ) posted Sun, 31 August 2008 at 8:10 AM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3232358&ebot_calc_page#message_3232358
Whoa. This is the opposite of what I"m used to. Is this a new behavior with SR3?
I (not too long ago) posted a bug with SM. The bug was: any object with the slightest amount of transparency on it is invisible to AO.
Now you guys are showing the opposite!
ice-boy ( ) posted Sun, 31 August 2008 at 9:30 AM · edited Sun, 31 August 2008 at 9:32 AM
i dont have SP3. so this is confusing.
now i know what happens. the AO is not from the boot but from the leg.
IsaoShi ( ) posted Mon, 01 September 2008 at 1:51 PM · edited Mon, 01 September 2008 at 2:05 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3231222
bb... I first came across this in P7 SR2. I posted a thread about it but I can't seem to find it now.
(edit) - found it, way back in May...
