Thu, Feb 6, 2:10 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
Subject: Displacement maps
Plotinus ( ) posted Sun, 31 August 2008 at 1:06 PM · edited Thu, 06 February 2025 at 2:01 AM
Hi there!
I'm trying to apply a displacement map in Poser 6 - to be specific, Carodan's wrinkle displacement map for Apollo Maximus. The problem is that it doesn't seem to be having any effect whatsoever. I have set it up in the Material Room, and the preview image there shows its effect. But there is no effect on the figure itself, in either preview or render. I've tried applying other displacement maps to other objects and they don't seem to show either.
Is there some basic trick here that I'm missing? How can the displacement map make a difference to the preview image in the Material Room but not to the object itself?
nruddock ( ) posted Sun, 31 August 2008 at 1:17 PM
Quote - Is there some basic trick here that I'm missing?
Could be, did you remember to tick the "Use displacement maps" option in the render settings ?
Nevare ( ) posted Sun, 31 August 2008 at 1:18 PM
Have the set the displacement option in the render settings? And set the displacement limits to 1?
Plotinus ( ) posted Sun, 31 August 2008 at 4:31 PM
I'm officially an idiot. Yes, I hadn't set it in the render settings. I didn't anticipate that there would be such a setting, because why would you apply a displacement map at all if you didn't want to use displacement maps? But such is the way of the world. Thanks for the help!
nruddock ( ) posted Sun, 31 August 2008 at 5:17 PM
Quote - ... why would you apply a displacement map at all if you didn't want to use displacement maps?
As doing displacement increases render time, it makes sense to be able setup the materials fully but turn off displacement to speed test renders.
