Wed, Nov 13, 9:27 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 12 7:17 pm)
Subject: [HELP] Problems in rendering
RedlanceEQ ( ) posted Sun, 31 August 2008 at 8:46 AM · edited Sat, 03 August 2024 at 12:33 AM
Hello all,
I know my question might sound stupid and might have an easy answer but after a day of search in multiple forums I cannot find the answer, leading me to think I must really be blind.
I'm trying to render a droid on a black backgound but for some reason I am unable to find out how to do it... All I have been able to produce so far is what follows:
Can anyone help me out?
Thanks in advance. :)
RAMWorks ( ) posted Sun, 31 August 2008 at 10:39 AM
Online Now!
Change your UI's background color to black and then render.  Save to a JPG. If you save to PNG then your going to save it out with a transparent background, which can work as well since you can then take your finished render into a image editing program and add in a layer, fill it with black and there you go (make sure your droid layer is the top most layer and the background layer is the bottom layer 😉 )
HTH's
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
RedlanceEQ ( ) posted Sun, 31 August 2008 at 10:56 AM
Quote - Change your UI's background color to black and then render.
Thanks for that and that is what I thought I had to do too but... where do I do that. All I found was the customize interface options and these do not affect the main window... :(
RHaseltine ( ) posted Sun, 31 August 2008 at 1:46 PM
Click the triangle button at the right-hand end of the horizontal arm of the camera/view control widget in the corner of the viewport to get the option menu.
darman42 ( ) posted Sun, 31 August 2008 at 2:26 PM
theres an optio in Edit on the toolbar of DAZ.
about...60%(?) of the way down is an option that has a sort of cliff-looking thingie, and is called
'edit background'.
just get a black jpeg image and use that for the background.
RedlanceEQ ( ) posted Sun, 31 August 2008 at 2:29 PM
It works. Finally. Thanks a lot for the help! :D
Better on black background. :D
