Mon, Nov 25, 11:37 AM CST
Subject: Sudden new error in Bryce
Nukeboy ( ) posted Mon, 01 September 2008 at 8:26 PM · edited Mon, 25 November 2024 at 11:26 AM
Well, out of the blue, I received the following error on activating DS through Bryce, I do not get the error if I launch DS 2.2 directly.  Anyone know what's going on (other than Marvin Gaye)?
I think I may have installed an item or two from DAZ, but I have not installed any new software that would invoke C++.   Hmmm.
Nukeboy ( ) posted Mon, 01 September 2008 at 8:33 PM
I should note that DS does seem to load and execute, but seems a bit slower...
staigermanus ( ) posted Mon, 01 September 2008 at 10:59 PM
Did you recently install other software?
PErhaps it's the C runtime library that's been changed to an older or newer version, and incompatible with Bryce. Unlikely, but possible. Even worse, perhaps that library was infected by a virus/spyware. Might want to run a full system, scan with Eset's oonline scanner (free, run it from inside Internet Explorer, see www.eset.com
I'd look to re-install the Visual Studio C runtimes, at download.microsoft.com
Or re-install Bryce to see if the version included with Bryce fixes the issue.
-Philip
thebest3d.com - beyond digital painting
nazul ( ) posted Tue, 02 September 2008 at 12:40 AM
Hello NukeBoy
You should create a file in your bryce directory named:
bryce6.exe.manifest
It should contain the following wich you can put in with notepad:
<?xml version='1.0' encoding='UTF-8' standalone='yes'?>
Best Regards
Arne
electroglyph ( ) posted Tue, 02 September 2008 at 9:38 AM
I recently loaded DAZStudio on a machine that didn't have it. During the install it loaded C++ runtime redistributible. I don't have any errors calling studio.
What version of Bryce, Studio, and what computer system are you using?
Nukeboy ( ) posted Tue, 02 September 2008 at 4:05 PM
No new software installs, DS worked fine until the other day.  Good idea about reloading the C redistributables.
Arne:  Sounds like you know something I don't.  What is the purpose of the bryce6.exe.manifest file?
nazul ( ) posted Tue, 02 September 2008 at 11:46 PM
Hi nukeboy
Well i guess it handles the communication and activation of DS and the back and forth communication between DS and Bryce - anyways - i had the same error (as many others) - and at DAZ3D one of the guys suggested the above solution except he called it bryce.exe.manifest - which didn't work - then another guy in another thread here at R someone suggested the above solution with naming it bryce6.exe.manifest which worked like a charm - reinstallation diddn't !!!
Best regards
Arne
Nukeboy ( ) posted Thu, 04 September 2008 at 3:53 PM
Thanks!  I'll give it a try!
