I don't use Anim8tor, I use Lightwave, so here is the Lightwave explaination : The polygons you can't see are facing the wrong way, and are not double-sided. Meaning, you can only see the ploys from one side, and it's not the side you're looking at. In LW, you simply select the polys and 'flip', or make the polys double sided. If you can find Anim8tor's version of the 'flip' command, you'll be set. Unless an Anim8tor user comes along a explains it better. Daeve
![file_183517.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_183517.jpg)
I am playing around with Anim8or to make some props. But when I import the prop into Poser I can 'see through' the item. That effect goes away upon rendering. See how the prop is not fully displayed in the first pic? Then it is in the rendered pic? Does anyone know what's going one here and/or how to fix it? MacXimus
