Wed, Jan 22, 6:13 PM CST
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Jan 22 4:32 am)
Check out the
Subject: Morphs in clothing?
liquidanime ( ) posted Mon, 08 September 2008 at 4:07 PM · edited Wed, 22 January 2025 at 2:59 PM
When you add in morphs for clothing that you had created using a 3D Modeler, what is the best way to do that?
We've currently completed pants that need to have morphs added, but we aren't sure what we need to do in order to add them in. Is there anything special or specific that it requires?
We used Hexagon 2.2 to create the model and Poser 7 is what we work with for the rest.
Any help would be very appreciated.
"Discover your dreams ... create them!"
manoloz ( ) posted Mon, 08 September 2008 at 4:30 PM
I am assuming your pants are conforming clothing?
There are several ways to do what you want, but you can try this:
  1. Export from Poser your pants as a Wavefront obj. Select the Save as Morph Target option. Make sure you ONLY export the pants.
  2. Import into your 3d modeler of choice.
    Note: The file will import in a very small scale. If that is an issue, you can use objscaler, just remember that if you scale the file, de-scale the files intended for Poser.
    If your pants are conforming clothing, you will see that you have different mesh groups corresponding to different body parts in Poser. So this can be a bit of a problem when doing morphs (but that's how it works)
  3. Do your morphs. Don't weld vertices, don't re-group meshes.
  4. Export each body part that you morphed as a single file (that is, one file for hip, one for lbuttock, and so on)
  5. In Poser, select each body part, and then with the menu, Object->Load Morph Target...
    Choose your file corresponding to that body part. Rename the morph to whatever name you want
  6. Do no. 5 for all body parts in the pants that were morphed.
If everything went as planned, you'll have new morph dials in your pants!
If you want to make a full body morph of the pants in the morphed state (so you can select the body part, and just spin a dial that will morph the whole pants in one go), set the morphed state of all the pants parts as you want them, and then do Figure->Create Full Body Morph.
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
nruddock ( ) posted Mon, 08 September 2008 at 4:49 PM
While the recipe given above is correct in general, if your using Hex 2.2 it won't work without an additional step (running a correction script) because that version reorders vertices during OBJ import.
Hex 2.5 is apparently fixed in this regard, so upgrade (it's free, requiring only a download reset at DAZ).
liquidanime ( ) posted Mon, 08 September 2008 at 6:23 PM
Thanks to both for replying to this, we'll look into getting Hex 2.5 to correct the stated problem. As for the steps,  yes the pants are conforming, so doing these will help out a bunch.
Thanks again!
