Fri, Nov 22, 4:13 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: MoI/Carrara Fun
bwtr ( ) posted Wed, 10 September 2008 at 1:55 AM · edited Fri, 22 November 2024 at 11:31 AM
I think the earlier thread shows that I have been loosing touch a bit with the Carrara Vertex Room.
Anyway, here is a bit of fun I had this pm with the MoI/Carrara6Pro combination.
Brian
bwtr
bwtr ( ) posted Wed, 10 September 2008 at 1:56 AM
And the render.
bwtr
GKDantas ( ) posted Wed, 10 September 2008 at 7:03 AM
Really cool! Can you send a printscreen from the wireframe mesh?
Follow me at euQfiz Digital
Sueposer ( ) posted Wed, 10 September 2008 at 10:10 AM
I am resisting taking up modeling, as it looks addictive. So I will comment on the render, which is so well done. That luscious realistic fur looks photographic.
GKDantas ( ) posted Wed, 10 September 2008 at 11:18 AM
Carrara fur is very good... can be better in future but its very realistic now.
50parsecs ( ) posted Wed, 10 September 2008 at 1:23 PM
It looks like MOI has a good exporter! Fur looks like mink! Well done. BTW, I've seen your recommendations about 3DCoat here and elsewhere, checked it out, and now I've decided to buy it before Sept. 15th 'cause the price is going up. Voxel-based sculpting sounds like a hell of a feature for the next version.
Edmund
bwtr ( ) posted Wed, 10 September 2008 at 6:39 PM · edited Wed, 10 September 2008 at 6:52 PM
Thanks all.
DKDantas
There is no wire mesh as such. The imported 3dm file is just in 4 parts much as shown on the MoI screen grab. (Outer shell,inner shell, "fur" beading, visor)
The parts are like primitives in the Assembly room and would have to be converted to be acceptable in the Vertex Room. Note that I don't use UVs in my renderings.
Brian
I hope the screen grab helps in my explanations.
bwtr
bwtr ( ) posted Wed, 10 September 2008 at 9:32 PM
And, a bit more crazy fun rendering in Carrara!
Brian
bwtr
GKDantas ( ) posted Thu, 11 September 2008 at 8:18 AM
Cool...maybe I need to take a look at Moi...
bwtr ( ) posted Thu, 11 September 2008 at 7:56 PM
Both MoI and 3D Coat are by one man geniuses.
Both are on forums to help customers or up date the apps with new things customers request, almost on an hourly basis. Staggering support for brilliantly conceived 3D tools.
Brian
bwtr
bwtr ( ) posted Thu, 11 September 2008 at 9:51 PM
If of interest to anyone,  I have made a little pdf of some of the simple construction moves in MoI and enclosed the resulting .car file. (It's a bit cleaner than my original effort--learning all the time!)
PM me if you would like it. The zip file is 528kb.
Brian
bwtr
Keith1961 ( ) posted Mon, 22 September 2008 at 3:36 AM
Hi
Just like to say I have been using Moi since last Christmas and its wonderfully quick and easy to use.  I think I might have given up modelling without Moi.  It has a friendly forum too.
Keith
UVDan ( ) posted Wed, 24 September 2008 at 8:35 AM
Forum Moderator
I cannot find the option to import a 3dm file in Carrara.
Keith1961 ( ) posted Wed, 24 September 2008 at 8:43 AM
Hi UVDan
Assuming you are using Moi, you need to export your model as an OBJ file.   Moi pretty much always makes an nice mesh and you can play with the export options if it doesn't.
Keith
UVDan ( ) posted Wed, 24 September 2008 at 2:32 PM
Forum Moderator
Thanks, I will try meshing my Rhino files in MOI.
bwtr ( ) posted Wed, 24 September 2008 at 5:26 PM
Carrara readily imports 3DM (Open Nurbs) files-----see attached
bwtr
UVDan ( ) posted Wed, 24 September 2008 at 5:47 PM
Forum Moderator
Thanks.  I will definitely have to see how Carrara handles Rhino files.
