Sun, Nov 10, 3:21 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Does Vue auto dectect processors?
MuonQuark ( ) posted Mon, 08 September 2008 at 7:54 PM · edited Sat, 09 November 2024 at 11:00 AM
I just purchased Vue 6 Pro but I'm not seeing the processors detected at the bottom of the screen.  Is there someone I need to do first?  I have looked thru the options but cannot find anything.
Thanks.
silverblade33 ( ) posted Mon, 08 September 2008 at 8:08 PM
Hm, tried restarting machine?
works a-ok on Infinite, I honestly cannot recall on Vue 5 Pro if it had such a feature then (as that's what I had).
what system do you have?
MuonQuark ( ) posted Mon, 08 September 2008 at 9:41 PM
Sorry.  Should have entered more information.  I ran Vue6 Easel and it detected both CPUs with no problem.  The comparative chart says Vue6 Pro should see both CPUs as well.  I have a Gateway GT5228 with dual AMD Athalon 64 X2 Processors 4200+.
I notice the renders are slower too.  I seem to recall having to do a quick install of something extra when I installed Vue6 Easel.  Maybe I need to look at the CD....  ::shrugs::
melikia ( ) posted Fri, 12 September 2008 at 4:37 AM
hi, muonquark...
yes, pro automatically detects the number of CPUs, however, it does not SHOW any indication of this.
right-click on window's task tray at the bottom of the screen, and bring up the task manager.  manipulate your windows so you can see it easy.  run a render and look at the performance tab on the task manager.  both (or more) windows should be running full-tilt.
hope this helps =D
~meli
Rarer than a hairy egg and madder than a box of frogs....
< o > < o >    You've been VUED!    < o > < o >
         O                                                    O
silverblade33 ( ) posted Fri, 12 September 2008 at 5:46 AM
MuonQuark,
hm, do as Melikia says and see if both CPUs are being used?
Problem is I have Infinte so I cannot compare directly :/
If the same scene with the same lighting type renders slower, that would be weird!
Maybe Pro is using more advanced lighting types? Radiosity?
Sorry I can't be of more help :)
melikia ( ) posted Fri, 12 September 2008 at 6:00 AM
esprit renders faster than pro... infinite renders faster than pro...
pro renders like a cow.
im ready to grab the bull by the horns already...
e-on, where's the sale i need!?!?
         O                                                    O
MuonQuark ( ) posted Fri, 12 September 2008 at 6:42 AM
Thanks for the replies.  I don't think it's broke but was curious about it.  Also, I could always use more memory....   :-)
Thanks.
