Wed, Dec 25, 12:10 AM CST
Subject: orthographic Render
Lord_Garland ( ) posted Fri, 12 September 2008 at 11:44 AM · edited Tue, 24 December 2024 at 12:11 PM
I am trying to do a over head view of a scene.
I am planning on using it for a game.
I am wondering if there is anyway to do a orthographic render? I want to create a map for my game so a top down orthographic view is what I need.
Thank you for your time.
bobbystahr ( ) posted Fri, 12 September 2008 at 12:02 PM
In the PLE version I play around with in the side bar at the camera slot  I would select top camera from the arrow drop down menu.. ...
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
Lord_Garland ( ) posted Fri, 12 September 2008 at 12:37 PM
I am using the top down view but I need a flat view.
Can I do any adjustments with the camra that might allow something close to this.
impish ( ) posted Fri, 12 September 2008 at 3:05 PM
Two possibilities:
  1. Render the top view by right clicking the icon to render the view and then do a screen grab to capture the render.  You can then piece several of these renders together - this is a true orthographic view.
  2. Select the Top camera.  Move it so its very high above the scene and then set its focal to a high number which will flatten the depth of field.
Neither of these is a 100% perfect solution but both can be made to work if you play with them a bit.
Lord_Garland ( ) posted Fri, 12 September 2008 at 3:14 PM
seems top view is a orthographic view after all. some trees on a slope made me think otherwise.
Just did a test with a tall box with red sides while white on top and bottom. Put to the bottom of the render view and did a 2880 by 2880 render. No red could be seen. so it seems to be orthographic.
Thanks for the help anyway. :D
Trepz ( ) posted Fri, 12 September 2008 at 3:15 PM
Oh hell, here it comes again... the unnecceasry admin blues....AAAHHH...EGADZ...MY EYES ARE BURNIN...
"Many are willing to suffer for their art. Few are willing to learn to draw."
Lord_Garland ( ) posted Fri, 12 September 2008 at 3:29 PM
Hey Trepz you just hit 1000 Posts. Congrats.
Trepz ( ) posted Fri, 12 September 2008 at 4:26 PM
NICE....um...huh?
alexcoppo ( ) posted Fri, 12 September 2008 at 4:30 PM
I confirm that apparently the top camera is orthographic (also in Pro). I created two cubes, one red and a slightly less large (in X,Y) green. I raised just a tiny bit the green cube and rendered with the  light coming from the top. As expected from an orthographic projection, I got a green square sorrounded by a tiny red border, of equal width on all sides.
This means that Vue can be used as a texture generation program: create the texture you want and apply it to the ground, put the sun right above and render appropriately!
Bye!!!
GIMP 2.7.4, Inkscape 0.48, Genetica 3.6 Basic, FilterForge 3 Professional, Blender 2.61, SketchUp 8, PoserPro 2012, Vue 10 Infinite, World Machine 2.3, GeoControl 2
