Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Yup. I know that, although I've used it successfully for several products in the past. On some things, it's a necessary evil.
And I did use 2 sets of morphs before at some point, although it was just an experiment. I probably didn't try to resave the prop, so wouldn't have noticed this problem.
No worries. I'll try to find some alternative way of doing it.
Thanks
mac
I have a drainpipe prop which uses alternate geometry and I've added 2 sets of morphs to it - 1 set for the regular geometry and 1 set for the alternate geometry. In poser, everything works until I try to resave the prop. If I've used the alt geom dial on the prop, then instead of saving this
prop drainpipe_1
storageOffset 0 0 0
objFileGeom 0 0 :Runtime:Geometries:maclean:room creator:drainpipe.obj
it saves this
prop drainpipe_1
storageOffset 0 0 0
objFileGeom 0 0
In other words, the geometry reference pointer disappears. This only happens if I've actually used the alt geom dial. If I don't touch it, the prop saves normally.
The alt geom code is fine, and I've changed the order of the channels, placing the alt geom channel above the morphs, among them and below them, with no success.
Any bright ideas?
TIA
mac
