Sun, Feb 16, 10:58 AM CST
Forum Moderators: Staff
Subject: Adding props with Readscript through a .pz2?
maclean ( ) posted Sat, 13 September 2008 at 12:21 PM · edited Sun, 16 February 2025 at 10:52 AM
I know I can call props through a .pp2 with Readscript, but can I do it with a pose file? I'd like to be able to add props to a scene, and pose them at the same time, but I can't seem to get it to work.
mac
EnglishBob ( ) posted Sat, 13 September 2008 at 1:32 PM
I think you'll find that Poser makes a fundamental distinction between library actions which add geometry, and those which merely modify the scene. As far as I know, "modifying" actions cannot be persuaded to add geometry no matter how hard you hack them. However, you should be able to do it the other way around, by reading a pose file from a PP2.
maclean ( ) posted Sat, 13 September 2008 at 6:32 PM
Thanks, bob. I'm sure you're right. I had a strong suspicion geometry couldn't be added through a pose file.
One more thing. I've just tried a (.pp2) readscript which calls two of the same prop, but it only loads one. I'm fairly sure poser won't do this due to the _1, _2 business. Just wondering if you'd ever tried it. A .cr2 doesn't do it either.
I'm kind of annoyed because I have a terrific script for daz studio which can call up any number of props, including multiple instances, and pose them, all in one file. I'd like to find a way to do the same in poser. Do you reckon python could do it? If so, I could check with Ockham.
Thanks
mac
EnglishBob ( ) posted Sat, 13 September 2008 at 6:59 PM
Poser Python certainly can do that - try the "Make Art" button which features in several of PhilC's utilities... Ockham has a script called Loader - "Multi-purpose helper to load lots of things at once." Sounds about right.
I haven't tried a dual PP2 load, but your theory about the numbering sounds plausible. LesBentley is offline following a house move; I'm sure he would know if there was an answer to that one.
Just thinking aloud here - a CR2 can load any number of props along with a figure. No ReadScripts are needed. A CR2 is effectively a mini-PZ3, except that it has no provision for lights (although even those might be hacked in). Might it be possible to use a dummy CR2 with nothing in it but prop references? You can only save parented props in a CR2 from within Poser, I think, but you could probably hack out the parenting afterwards if that isn't wanted.
maclean ( ) posted Sun, 14 September 2008 at 4:57 AM
Thanks, bob. Now that I think about it, python is probably the way to go. I'll check out those scripts you mentioned.
It would probably help if I explained what I'm trying to do. I'm building a pack which has a system of modular drainpipes, pipes and cables (on the exterior of a house). Each set has a number of basic components and the user fits them together to match the structure of their house (Room Creator, which is also modular).
My idea was to include a bunch of pre-prepared files, but rather than save entire collections of props, I thought of using Readscript to build the sets. Now that I have the daz studio script, a simple pose file which can load any number of figures or props, and pose them, I'm hoping to find a Poser equivalent. If there's no way to do it, I can always save prop sets in the poser version, but I always prefer to make both versions of a product as similar as possible. Not only that, since I mainly deal in complex scenes, a workable system like this would be useful to me for all sorts of other things.
Oh, and thanks for news on Les. I haven't spoken to him for a long time, but before I asked in here, I searched this forum for both the subject and his name. I'd forgotten just how many weird and wonderful things he's come up with - lol.
cheers
mac
PS If you use daz studio and want to try that script, it's here. There's a downloadable file with samples, ready to go.
http://forum.daz3d.com/viewtopic.php?p=1428914
Cage ( ) posted Thu, 18 September 2008 at 12:14 AM
A pose can be used to add geometry to a scene via a geometry insertion pose.  I don't think it can add the actor into which the geometry is to be inserted, however.  It has to be inserted into an existing actor in the scene.
ockham ( ) posted Thu, 18 September 2008 at 12:47 PM
Look especially at the LoaderLocate version.
http://ockhamsbungalow.com/Loader/LoaderLocate.zip
A simpler option, if you don't need 'infinitely flexible' locations,
would be to smart-prop the gutters to their proper spots and
package them together in the same PP2, like a pair of shoes.
My python page
My ShareCG freebies
maclean ( ) posted Thu, 18 September 2008 at 2:29 PM
Thanks ockham,
I downloaded LoaderLocate and I'll have a look at it.
I had a feeling I'd end up with python for this. My only hesitation is the things I keep hearing about some scripts not working from version to version.
mac
ockham ( ) posted Thu, 18 September 2008 at 2:47 PM
OK.  If you want to do this the Python way, get in touch with me.
My python page
My ShareCG freebies
