Fri, Nov 22, 12:12 PM CST
Subject: Magnets....
Inspired_Art ( ) posted Fri, 19 September 2008 at 12:39 AM · edited Fri, 22 November 2024 at 12:10 PM
Ok, so in Poser 7 I used a magnet to eliminate poke-through on a bikini top. now what is it that I do? I have the magnet and all it's "children" showing.
Eddy
geep ( ) posted Fri, 19 September 2008 at 2:28 AM · edited Fri, 19 September 2008 at 2:30 AM
Hi Art, 😄
Here's what to do next ...
  1. Select the body part that has been deformed with the magnet(s) ...
  2. Use the [menu] "Object" >>> "Spawn Morph Target" (name the morph, e.g., "bikinitop")
Now the "Morph" will appear as a new parameter dial for that body part.
  1. Select the Magnet (or Base, or Zone) and DELETE the magnet(s)
After you have deleted the magnet(s) ...
The deformations will disappear until you set the (new) "Morph" parameter dial to 1.000
(or any other setting that you want).
Repeat the steps above for any other body parts that have been deformed.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Inspired_Art ( ) posted Fri, 19 September 2008 at 2:40 AM
Hallelujah! There is a God above!!!! Thank you so much Geep! I highly appreciate it! :biggrin:
Eddy
geep ( ) posted Fri, 19 September 2008 at 2:49 AM
Quote - Hallelujah! There is a God above!!!! Thank you so much Geep! I highly appreciate it! :biggrin:
There is indeed and I thank Him daily for what I have ...
...and the ability to share it with good folk like you ... and you are quite welcome.
Go now and make beautiful renders. 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Dead_Reckoning ( ) posted Fri, 19 September 2008 at 9:05 AM
While we have you here.
I am attempting to convert a v4Hair (Free Boy Hair for v4) to a F2Male.
With x,y,z I can get a pretty good fit.
It is however too wide (x axis) for his head in way of the area over his ears and sideburns.
There are no seperate zones in the Boy hair.
How would you set up a Magnet or Magnets to bring both sides of the hair in towards the head?
Something like bending the base of the magnet forks inward.
"That government is best which governs the least, because its people discipline themselves."
Thomas Jefferson
hborre ( ) posted Fri, 19 September 2008 at 9:24 AM
I pick this up recently but haven't had a chance to play with it.  Maybe it would be better to scale the entire hair smaller then pull the x axis out rather than in.  Pulling in might create a dent effect.
geep ( ) posted Fri, 19 September 2008 at 10:00 AM
@  mariner
One could use the Grouping Tool to make a separate group (or groups) within the hair prop and then use a magnet to affect only that group.
Hmmm ... is it time for another Magnet tut? 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
nyguy ( ) posted Fri, 19 September 2008 at 10:44 AM
Sir May I have another Tutorial?
Poserverse The New Home for NYGUY's Freebies
dlfurman ( ) posted Fri, 19 September 2008 at 11:04 AM · edited Fri, 19 September 2008 at 11:05 AM
...and don't forget to SAVE the item! So you can use it again.
geep ( ) posted Fri, 19 September 2008 at 2:02 PM
Attached Link: "Magnets" tutorial compliments of Dr Geep Studios
*(click image to view full size) (click link above image to view comple tut)*
Here's an oldie but a goodie ... see if this answers your questions. 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
momodot ( ) posted Fri, 19 September 2008 at 2:14 PM
Attached Link: No Poke (python)
ockham has in freestuff a little script that fixes poke-through in most cases with the click of a button.
nyguy ( ) posted Fri, 19 September 2008 at 3:35 PM
Quote - ockham has in freestuff a little script that fixes poke-through in most cases with the click of a button.
Do you know how it works on boots? Have a set of shoes where the heels of the feet poke thru after conforming. This is something of a pain in backside for me.
hborre ( ) posted Fri, 19 September 2008 at 3:42 PM
Try making the feet invisible if the rest of the leg is hidden by trousers.
Inspired_Art ( ) posted Wed, 24 September 2008 at 12:42 AM
Thank you so much Dr Geep! You the man! :thumbupboth: :thumbupboth:
Eddy
