Tue, Nov 26, 6:04 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 5:46 am)
Subject: Poser 7 freeze when deleting anything or rendering anything. Any help please.
rowlando ( ) posted Mon, 22 September 2008 at 6:49 AM · edited Tue, 26 November 2024 at 6:04 AM
HI any suggestions re the title.
I have completely removed The program and reinstalled including adding all the updates SR1, 2 and 3. I the program installed in the main C hard drive.
I am running the program on its main runtime only not my normal external runtimes.
I load a primative ball, and then render which cause the program to Freeze up and lock. It also dose the same thing when I try to delet anything prior to render.
The program started doing this about 1 week ago and I simply reinstalled the main files but now nothing works.
Any Ideas.
Seek what you can never loose
rowlando ( ) posted Mon, 22 September 2008 at 6:58 AM
I need to add. I have installed two programs called Face Gen Demo and 3DI runtime installer. Before these problems happened.
I have also found a folder  in my main C drive called System Volume Information, this folder will not allow me access, says Access is denied, its properties  say read only, and has no bytes used according to properties info.  It was created 8th march 08. I have scanned this file for virus ( NONE found ) and my PC is also been scanned no virus found. I run Trend Mircro Security Pro to protect my system.
Thanks Rowlando
Khai ( ) posted Mon, 22 September 2008 at 7:10 AM
erm leave System Volume Information alone! it's a major system area, that holds your restore points.
http://www.theeldergeek.com/system_volume_information_folder1.htm
rowlando ( ) posted Mon, 22 September 2008 at 7:54 AM
Yep thanks  Khai I wont do anything to that file
Rowlando
hborre ( ) posted Mon, 22 September 2008 at 8:32 AM
If the problems began when you installed Face Gen Demo and 3DI runtime installer, I suggest uninstalling each separately and then run Poser.  It may just be that the programs are not agreeing with each other.
ranman38 ( ) posted Mon, 22 September 2008 at 9:02 AM
crazy as it sounds, update your video card drivers. I had the same problem and that fixed it. Including slow moving dials and other various issues.
rowlando ( ) posted Tue, 23 September 2008 at 1:43 AM
Thanks ranman38 I tried your way and it seems to have worked, strange this poser software.
thanks again to all the help above.
rowlando
