Sun, Feb 9, 5:55 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: my reoccuring error
brenthomer ( ) posted Mon, 25 June 2001 at 5:19 PM · edited Sat, 08 February 2025 at 9:40 PM
I have a "Nil Pointer Error Has Occured" error I can not get rid of!! Last time due to help from this board I found out that b/c my textures where spread out all over the place Carrara was freaking out. This time I consoldated all the files onto one drive and I still get the error. Next I decide that maybe the textures where just too large. I turn an 8gig photoshop sequence into a 700meg jpeg sequence and I turn a 550 meg avi to a 20meg jpeg sequence...still I get the NIl Pointer error. If I use goroud shading for the render its fine, but If I use t-maps it screws up. I really cant compress anymore. I have tried making this work on a system with 385megs of ram and another with 512 megs and its still kicking out the error. Anyone else have any suggestions? Its annoying b/c the first frame always renders and saves, the second frame renders then crashes. Man this stinks!
brenthomer ( ) posted Tue, 26 June 2001 at 8:36 AM
Well this is my Third big animation with this error and i have found a temporary work around, And I suspect that others will eventually run into this. Apparently Carrara is having problems with the post-effect filters. While I am not a programmer and do not know this for sure, my last two animations kept puking with the motion blur filter on and this one kept puking until I removed the aurora filter. So just a word of warning :)
litst ( ) posted Tue, 26 June 2001 at 9:17 AM
Thanks for the tip, Brent . I've found the aura filter a bit buggy sometimes ... Didn't know it could cause this kind of problems . Usually, i prefer using Glare : more options and more stable . Keep us updated about your anim ! litst
