Fri, Nov 22, 8:42 PM CST
Subject: removing the green background blend
TheOwl ( ) posted Tue, 23 September 2008 at 2:13 AM · edited Fri, 22 November 2024 at 4:16 PM
I had this scene where there are characters plus environments and effects which the last two were props.  I want to do separate renders of these three and just put them together in a video editor so I painted the background green and hid the parts not included.
The problem is the muzzle flash above. The green have blended with the transparent yellow at the edges that when I remove the green, the "blended green" is included as you can see from the image above.
Any suggestions to completely  remove the green?
Passion is anger and love combined. So if it looks angry, give it some love!
dphoadley ( ) posted Tue, 23 September 2008 at 3:38 AM
Rerender, and save as PNG's.  B ackground remains transparent that way.
DPH
ghonma ( ) posted Tue, 23 September 2008 at 5:03 AM
And set your 'render over' to 'black' if you use png. This will give you a nice clean alpha. Otherwise you may get a fringe of color that's hard to remove.
gmadone ( ) posted Tue, 23 September 2008 at 10:15 AM
Translucent data is not stored in the alpha of a .png, just the transparent. Your backgrounds must match, for the translucent parts to look right. Black on black is the easiest, but if you use black behind your flash and don't have a black background in your sceen, your flash will have a noticable black edge.
If you want complex translucents data, you will need to add the effect to your sceen.
There may be another way around this in paint, that I am unaware of.
TheOwl ( ) posted Tue, 23 September 2008 at 11:25 AM
Quote - And set your 'render over' to 'black' if you use png. This will give you a nice clean alpha. Otherwise you may get a fringe of color that's hard to remove.
I didn't get what you mean with this. And I do used a .png on the image above.
TheOwl ( ) posted Tue, 23 September 2008 at 11:34 AM · edited Tue, 23 September 2008 at 11:36 AM
You know what I get it now. I saved the pic as a .png and the background painted black. I tested to the image above and it did the trick.
So simply put I must render in .png's for now on. Anything bad about using other filetypes like .tif's?
