Sat, Jan 25, 5:52 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Subject: Poser7 clothing question.
uncle808us ( ) posted Wed, 24 September 2008 at 11:05 AM · edited Sat, 11 January 2025 at 8:00 AM
First I am using a Mac OS 10.4 Tiger.   I have been trying to make clothes for poser figure M3. I’m using Cheetah3D for modeling and OBJ2Cr2(first) as well as WardrobeWizzard 2 (to fit) . (PhilC) I’m having some problems (in Poser7) due to my confusion, I have read docs and some tutorials.   Here is one question why do I have the messed up shirt after posing. and what is the problem with the texture on the pants legs? The template uv’s are not showing in the final texture.( I did the uv template in Cheetah3D.)   Well that’s enough questions for now my brain hurts.LOL.
MacBook Pro OSX El Capitan Ver 10.11.6
Gareee ( ) posted Wed, 24 September 2008 at 11:15 AM
pants look like bad uv mapping to me...
uncle808us ( ) posted Wed, 24 September 2008 at 11:29 AM
Here's what my uv map looks like.
PhilC ( ) posted Wed, 24 September 2008 at 12:03 PM
ahh the power of copy/paste :)
If the shirt is not folding as you would like it then you'll need to adjust the joint parameters. Included in the OBJ2CR2 help files is an on screen video tutorial on joint parameters.
The pants need more polygons. Poser does not play nice with lots of long thin faces.
uncle808us ( ) posted Wed, 24 September 2008 at 12:07 PM
Ahaaa! OK I'll work on that. Thanks
nyguy ( ) posted Wed, 24 September 2008 at 12:07 PM
Here is what I recommend, try setting the smooth dial to one and see if that helps your issue with the shirt, as for the pants, try going into the the mat room and check normals face forward and see if the issue is fixed.
As for the UV Map, very bad mapping done by this program, I don't know if UVMapper has a MAC version but you need to get that map fixed.
Poserverse The New Home for NYGUY's Freebies
uncle808us ( ) posted Wed, 24 September 2008 at 12:10 PM
Thank you I'm working on that bad uv.
uncle808us ( ) posted Wed, 24 September 2008 at 4:52 PM
Problems solved using joint editor and making a new UV map. Thanks everyone.
