Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 11 12:18 am)
ahh the power of copy/paste :)
If the shirt is not folding as you would like it then you'll need to adjust the joint parameters. Included in the OBJ2CR2 help files is an on screen video tutorial on joint parameters.
The pants need more polygons. Poser does not play nice with lots of long thin faces.
Here is what I recommend, try setting the smooth dial to one and see if that helps your issue with the shirt, as for the pants, try going into the the mat room and check normals face forward and see if the issue is fixed.
As for the UV Map, very bad mapping done by this program, I don't know if UVMapper has a MAC version but you need to get that map fixed.
Poserverse The New Home
for NYGUY's Freebies
MacBook Pro OSX El Capitan Ver 10.11.6
