Sat, Jan 25, 8:37 PM CST
Subject: Cloud Detail
LMcLean ( ) posted Thu, 25 September 2008 at 12:59 PM · edited Sat, 11 January 2025 at 7:06 PM
When creating a cloud the default clouds usually render with a lot of grain. I can't seem to figure out how to change this so the cloud still retains it's current shape but the grain is reduced.
I selected the cloud material and went into the function editor and reduced the settings but the clouds ended up filling in and the clouds became more "dense". I want the shape to remain the same only the grain to be reduced when rendering.
Where do I change this setting?
Thanks
Trepz ( ) posted Thu, 25 September 2008 at 1:03 PM
you can turn your atmo quality up in the sky/fog/haze tab
"Many are willing to suffer for their art. Few are willing to learn to draw."
LMcLean ( ) posted Thu, 25 September 2008 at 1:27 PM
Which of the settings would I use to accomplish this? I see the "quality boost" setting is set to 4.00 does this need to be uppped and how high should I go?
Thanks
Rutra ( ) posted Thu, 25 September 2008 at 1:43 PM
Trepz suggestion may eventually not be sufficient in all cases and in all types of clouds. In some cases, you may also want to increase anti-aliasing settings (number of subrays and quality). For example, in some of my recent images with clouds, I had to increase AA quality to 98% and subrays max to 20 or more to get rid of grain.
Rutra ( ) posted Thu, 25 September 2008 at 1:44 PM
Ooops, we cross posted. That's precisely what I was saying, increasing quality there is not enough in some cases. You aparently found one of those cases.
I noticed you have lots of fog. That can also help to produce grain.
Trepz ( ) posted Thu, 25 September 2008 at 2:00 PM
Rutra is correct. Shadow density also can effect grain, as can aerial perspective with Volumetric and so can god rays for that matter:D So basically just fiddle around with it. But generally turning up your AA and boosting quality helps, but i wouldnt go to far past 4 as it can take a real hit on memory.
