Thu, Nov 14, 5:55 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: poser 7 content into poser pro
bigdave1960 ( ) posted Fri, 26 September 2008 at 3:31 PM · edited Thu, 14 November 2024 at 5:46 AM
having amassed quite a lot of content in poser 7 (some of it abit messy in side poser folder) i was wondering if it is possible to easily transfer the content from poser 7 to poser pro. Or even just make it so that poser pro could access the stuff in poser 7 with out having to keep searching for everything
Khai ( ) posted Fri, 26 September 2008 at 3:33 PM
just link the P7 runtime to the PP one as an external
bigdave1960 ( ) posted Fri, 26 September 2008 at 3:36 PM
forgive my ignorance but how do i do that
IsaoShi ( ) posted Fri, 26 September 2008 at 4:00 PM
Go to the top level of your Library, click the + button (down the bottom) to add a new Library, and then select the Poser 7 folder which contains the Runtime with all your content.
Izi
nghayward ( ) posted Fri, 26 September 2008 at 4:02 PM
Go down the folders in the library until you get to the poserpro and download runtimes showing
Click the  + button at the bottom of the library.
Browse to and select the Poser 7 folder (program files/ efrontier/poser7 I think)
You then have an extra runtime called poser 7 to use
bigdave1960 ( ) posted Fri, 26 September 2008 at 4:06 PM
thanks very much that works  so easy when you know how thanks again
