Thu, Jan 23, 7:27 PM CST
Subject: Question about joint editor
smalll ( ) posted Tue, 23 September 2008 at 12:35 AM ยท edited Sat, 18 January 2025 at 12:05 PM
Hi.
I need your help very much.
I want to make my model.
Please see below image.
I want to make like this.
You can download my file.
http://www.bokgi.net/test/question.zip
How can I fix it?
What's wrong with me?
Could you help me please?
PhilC ( ) posted Tue, 23 September 2008 at 6:44 AM
How did you create the figure, was it by:-
a) Writing a hierarchy file (PHI) and using the Poser menu File > Convert Hierarchy file.
or
b) Importing the model and using the set up room?
I'm going to guess that you used wrote a hierarchy file.
What rotation order did you use for the "down" part? In the model it is XYZ, was it that in the hierarchy file or did you change it later using the joint editor? Or maybe you changed the up rotation order?
Somewhere, somehow this has got corrupted. The down sees the up rotation order as XZY, the up sees its rotation order as YXZ. They must match. I seam to remember that Poser 5 was less sympathetic to users changing the rotation order. If I am correct, you have not done anything wrong but Poser 5 has not been able to correctly accommodate your editing.
Try again using this hierarchy file:-
objFile :Runtime:Geometries ------ etc
1 down yzx
2 up yzx
geep ( ) posted Tue, 23 September 2008 at 9:46 PM
Attached Link: Creating Poseable Props & Figures
Hi Smalll,
Maybe this tut could help. Click this link or the link above the image here.
See Page 25. ๐Ÿ˜„
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
smalll ( ) posted Sat, 27 September 2008 at 7:03 AM
Thank you both of you.
I'm sorry about late.
Thank you.
geep ( ) posted Sat, 27 September 2008 at 8:49 AM
It is never too late to say thank you ... and ... you are welcome. ๐Ÿ˜„
cheers,
dr geep
P.S. Did you get your figure fixed? :blink:
cheers,
dr geep ... :o]
edited 10/5/2019
