Also, for somethings , like say an indoor room, such as a Poser library or dinner room or whatever, since it's a closed room, the light sucks in the save object preivew, if you save the object all you get is mostly darkness for a preview :(
So, in Infinite, render out a 200x200 image, appropriately lit, then use THAT as the preview image Dunno what other versions have that feature.
When saving item:
**Preview --> Use Custom Image
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
If you want to save a preview of an indoor, another possibility is to uncheck the "use global illumination" and check "use local light". In this case, the preview uses whatever lights you placed inside the room to render the preview. Sometimes it's a bit hard to find the right POV but it's possible.
Hi everyblody... someone knows if is possible to enlarge the objects in the window? Sometimes the object is perfect and visible... but in most cases the object is distant and quite difficult to identify. Any tips? Thanks in advance.
