Fri, Feb 7, 7:11 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: Rendering Hair in Poser6
rockets ( ) posted Fri, 10 October 2008 at 7:30 AM · edited Fri, 07 February 2025 at 6:42 AM
I hope ya'll will bear with me on this, because I know this question must have been answered a thousand times before.  I'm trying to render the Sapphire Fox hair in Poser6 and no matter what texture I put on it, it comes out white in the render.  I checked the material room and even though the hair texture is there in the drop down box, it's showing white as the material.  I can change it manually, but it reverts back to the white.  How do I make the texture stay put?  Thanks for any help.
My idea of rebooting is kicking somebody in the butt twice!
hborre ( ) posted Fri, 10 October 2008 at 8:39 AM
How are you applying the textures?  According to the features list @ DAZ, the file also has MAT Poses for loading the textures and transparency maps.  Check the Pose section in your library palette for those files.
rockets ( ) posted Fri, 10 October 2008 at 8:42 AM
I just use the Mat poses as I always do.  I seem to have this problem with various hair props.  I know it's something to do with Poser6, I just don't know what.
pitklad ( ) posted Fri, 10 October 2008 at 11:51 AM
Maybe try to apply the mat pose while you are on the material room and not from the pose room
My FreeStuff
nghayward ( ) posted Sat, 11 October 2008 at 4:54 PM
I've don't remember having a problem with Saphire Fox Hair in poser 6. But I'm using Poser 7 and I it's been a while since I used it in Poser 6.
It comes as a prop and conforming versions do you have the problem with both or just one?
Were the MAT files the ones that came with SFH or are they third party?
Dizzi ( ) posted Sat, 11 October 2008 at 5:16 PM
Is texture strength set to 1 on the image node?
nghayward ( ) posted Sat, 11 October 2008 at 5:21 PM
Quote - Is texture strength set to 1 on the image node?
No it's not. Just tried it out in Poser 6 and was coming back to mention it. noted that the texture strength was 0. but if you use the mat poses included they change the strength to 1
