Community Center F.A.Q (Last Updated: 2025 Jan 17 10:49 pm)
Recently I've noticed that I've been getting a lot of sql errors when I try to post. Below is the error message. Note that this doesn't prevent the post from happening, but it shows up instead of taking me back to the forums.
[quote]
MySQL error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-31,30' at line 3, occured in query: "SELECT SQL_CALC_FOUND_ROWS t.* FROM forumpro_message t WHERE t.thread_id='2752435' AND t.status = 'active' ORDER BY post_date LIMIT -31,30;".
[/quote]
Is anyone else seeing this?
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
