Try a different display mode, like hidden wireframe?
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
There is an option to switch this off, but I'm at work and I can't remember it. Look under the Display menu for something like "Show selection outline...", and untick it. As I say, i can't remember exactly what the words are, but it's there!
Izi
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
If you have access to practically any modeling application, you'll find that selecting polygons for this kind of purpose is MUCH MUCH EASIER. Poser's Group Editor is terrible compared to pretty much any other tool.
Quote - There is an option to switch this off, but I'm at work and I can't remember it. Look under the Display menu for something like "Show selection outline...", and untick it. As I say, i can't remember exactly what the words are, but it's there!
Izi
Thank you so much, I'll have to try that! :) I'll let you all know if it works.
--R.
Quote - If you have access to practically any modeling application, you'll find that selecting polygons for this kind of purpose is MUCH MUCH EASIER. Poser's Group Editor is terrible compared to pretty much any other tool.
I have ZBrush, CInema and Truespace. Will any of these do the same thing? I'm unfamilar with grouping in this way in other programs.
--R.
It is stored in your user profile.
In Windows XP I think the path is:-
C:Documents and SettingsLocal SettingsApplication DataPoser 7Poser.ini
(But you already know about my memory).
In Mac OS X the file is:-
/Users//Library/Preferences/Poser 7/Poser Prefs
(I cheated and looked).
(edit) If you are in Windows and you can't see the Local Settings folder, you will need to tick "Show hidden files and folders" in your Folder Options. Or just type the full folder path into the address toolbar.
what I should be."
Murakami)
Thank you so much!
I'm a Vista user, however your instructions still helped me find the directory. For Vista, this is the directory you might want to look for it in: C: Users AppData Roaming Poser 7 Poser.ini. Hope that is helpful to any Vista users using Poser!
Thanks again! I'm going to see if that works now. :D
--R.
UPDATE: It works! Thanks to all who've helped me with this issue! I hope this thread is of help to others!
I'm working with the grouping tool in the hair room trying to make a stubble prop. Everytime I try to select anything, it shows up selected like this in a green outline (see attached picture.) Is there any option to turn this feature off? It makes it hard to focus on close details when trying to work in the hair room especially.
Thanks in advance!
--R.
