Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 31 7:44 am)
You will probably get better results if Bagginsbill comes along but you're welcome to the "Bloodpool" material in the Dark Sorceress / Demonatrix materials in my freebies, it's not exactly blood because there is some variation in color but you could take that out pretty easily.
Dunno, I think it is more about bump - since the surface beneath a thin film of blood is not perfectly regular, the layer of blood itself would not be perfectly flat, so imo some bump is mandatory. There is some procedural bump in my shader that looks more like a countour map, so it isn't really great for simulating blood perfectly but the color and specularity, I think they're okay. A bit cinematic though, it looks VERY wet (probably more than it should if it were real blood).
Hmm. Because Poser does not implement real SSS, I'd have to design the shader in context. A bowl of blood, a drop of blood on a surface, or a thin layer of blood on skin would all be different.
What's the context. Is there a prop involved, like a splatter? If so is it your own and you can give it to me to work with?
hi, i'm wondering if anyone has advice on a blood shader? i'm not thinking about the most realistic results, because the image i'm working on is fairly stylized. slick, red and reflective aren't so much my worry. i'm wondering how you make it look viscous and obviously liquid and not glass.
