Thanks for your reply. Actually I need one that will take a black & white tif, jpg, etc. of a shape and turn it into a 3D object. I just rememberd that 3DF/X by Asymetrix will do this (it's completely automated and very cool), but unfortunately you can not export the object at all. And working in 3DF/X is a nightmare. It's amazing to me that a cheap little program like this has this capability and nothing else seems to ... astounding really. Would the VectorWorks plug-in be able to simulate 3D on a non vector-based image though?? Thanks, Tim
Attached Link: http://www.best.com/~calyxa/pearl/clipart.html
This is a nice tutorial on using clipart..the basic principal is the same... http://www.geocities.com/cartesius44/index2.htm This one is nice too...holler if you need more help..bryce can basically do anything..just have to learn how.If you're using it for text, or whatever kind of object you're making, make sure to keep the grid size LARGE! 1024 is what I generally use for latices and terrains. This helps so that you won't get any jaggies on the edges. Also if you're using photoshop for the grayscales, you'll want to turn the antialiasing off on the text in photoshop. Then if you apply a nice, little gaussin blur to the object you'll get very smooth edges, play around with the settings in your image editing program and in Bryce... Hope that helps, Jared
This one really isn't a bryce answer for me, but it works... You mentioned other 3D apps like max? What I tend to do a lot is do the line art in Illustrator, then import the .ai file into max and extrude it as a 3D mesh. I also do 98% of my text extrusions that way for 3D type also. Rhino will do it also, but Rhino prefers .dxf line art to .ai files. On a bit map or something similar, I do the line art on another layer over the bitmap, then delete the bitmap layer.
"I am a good person now and it feels... well, pretty much the same as I felt before (except that the headaches have gone away now that I'm not wearing control top pantyhose on my head anymore)"
Hi, I was just wondering if there was a way in Bryce (or any other 3D program like Max, RayDream, TrueSpace, etc.) to take simple 2D line art and extrude it into 3D object. There was a program called AddDepth by RayDream a while ago that would do this quite well. It simple pulled 2d art or text into a 3D shape. Will Ilustrator do this maybe? If no one knows what I mean, I can post some examples here. Thanks!! -Tim
