Thu, Nov 28, 8:51 AM CST
Subject: texture problem: blocking occuring, pixel sample number affects it, but no cure
eyeorderchaos ( ) posted Thu, 30 October 2008 at 9:42 AM · edited Thu, 28 November 2024 at 8:33 AM
Okay, I made a "green paint splotch" with an alpha map for transparency, and applied it to a square (from props>primitives). This worked fine (transparency wise), and looks just fine in the preview, but when rendered it has serious blocking. The blocking is just that,  blocks, which divide the texture into square chunks of two different luminosities, it looks like...normal, and darker-than-normal. The only fiddling that seems to affect this situation directly is to change the pixel samples number in the render settings, but this is no cure as the results are unacceptable. The texture has enough resolution (it's not a close-up shot), and so this is not pixelation per se (at least, I don't think so). Any answers? Thanks!
elzoejam ( ) posted Thu, 30 October 2008 at 9:47 AM
Have you tried reversing the normals? You can click that option in the material room, it sounds like the problem you're having but without a picture I can't be sure.
-Sarah
eyeorderchaos ( ) posted Thu, 30 October 2008 at 9:48 AM
ps
min shade rate also directly affects it, but no cure.
When I say "directly affects" it (both in pixel samples and min shade rate), I mean it changes how big the chunks are and how the chunks are "patterned". But, no cure. The cure would be, the lighter luminosity would be uniform.
eyeorderchaos ( ) posted Thu, 30 October 2008 at 9:51 AM
Sarah, thanks! That's the cure! Normals, forward!
Project, forward!
ur beautiful!
elzoejam ( ) posted Thu, 30 October 2008 at 12:50 PM
Glad I could help :-)
-Sarah
