Poser - OFFICIAL F.A.Q (Last Updated: 2026 Mar 09 10:48 pm)
Dear Dr. Geep, am very GLAD to see you're back, you've been missed!
DPH
I'm now feeling myself around Poser Pro.
DPH
... we can change the Display Style for the GROUND if we ...
CLICK on the little UP ARROW in the small circle on the right end.
Now, the GROUND prop will follow the Document Display Style.
Let's switch back to the Document Display Style and Select Smooth Lined.
cheers,
dr geep ... :o]
edited 10/5/2019
Did you know that ...
Poser's GROUND (prop) is NOT "on Poser's "Floor?"
Poser's "Floor" is where yTran is equal to exactly 0.000 ... but ...
Poser's GROUND prop is at a fixed yTran location of (minus) -0.001
Do you know how we can prove this is true?
BTW - The "Drop to Floor" command works for prop (objects), also !
(except the GROUND prop because there is no DollyY parameter for the GROUND)
Let's try a little experiment to prove this is true ...
cheers,
dr geep ... :o]
edited 10/5/2019
Quote - Thanks Lostin ...
Thanks for the lesson Sir.
Question
Does reversing my steps Turn it back off?
Sorry, I just am not seeing the benifits here.
I like my Grounds as wire, I use it for positioning.
But I like my figures Texture Shaded.
Thanks
"That government is
best which governs the least, because its people discipline
themselves."
Thomas Jefferson
Hi mariner ... glad to have you join us ...
You're quite welcome.
Question
"Does reversing my steps Turn it back off?"
Yes ... you can set the Display style of the GROUND to anything you want.
This is an optional thing to do and I have only included it here to give you one more "tool" to keep in your Poser "bag of tricks."
Thanks for the question ... it's a good one.
BTW - You can keep your GROUND as wireframe if you want ... it will not affect what we are going to do next.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
... Display Units ...***
***Here's what to do to set the "Display Units" ... to "Poser native units" **<<< USE THIS ONE !!!
Use the [menu] "Edit" >>> "General Preferences..."
Select the "Interface" tab and ...
cheers,
dr geep ... :o]
edited 10/5/2019
If we don't do this ... the parameter values that we will use may not work properly.
___ That sucks!
Why do we want to use "Poser native units?" (Pnu's) ... Stay tuned and find out why ...
Hi hborre ... Thanks for tuning in ... and ... You're welcome. ...
cheers,
dr geep ... :o]
edited 10/5/2019
Why do we want to use "Poser native units?" (Pnu's)?
Anyone? ..... Anyone? ..... Anyone? ..... Bueller? ..... Bueller? ..... Anyone?
The first correct answer (posted here) wins a "Wacky World" CD.
Anyone ??? :blink:
cheers,
dr geep
to be continued ...**
cheers,
dr geep ... :o]
edited 10/5/2019
Thank you for this, Doc!
Native units? I would guess that it's to eliminate any decimal rounding in the conversion that Poser does when you use another unit. ??
I must say I assumed Amloid was just NSG's big sis... If not, she jolly well should be.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
We have a WINNER !!!
***>>> giorgio_2004 <<<
Different versions of Poser may use different conversion factors for size (x,y,zScale) and distance (x,y,zTran) for Real World Values, e.g., feet, inches, meters, etc. but Pnu's are always the same.
But ........ I liked the answer that replicand gave, also, because it is TRUE.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: Click here for Doc's FREE Scale Props for Poser
Good Morning Folks,
Today we will be covering ... well, we will try to cover some more fascinating stuff in the wonderful world we call Poser.
Before we get started ... and doing this is optional (but FREE) ... you might want to get a copy of my Scale prop(s).
There's a 9 foot prop with markers down to 1/10 of an inch.
There's a Metric 1 meter prop with markers down to 1 millimeter.
You can view both of the Scale Props HERE. :thumbupboth:
... and/or ...
Download the FREE 9 Foot Prop HERE.
... and/or ...
Download the FREE 1 Meter Scale Prop HERE.
We'll get started on today's lesson in a little while.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Good Morning Folks,
cheers,
dr geep
Where is My desk, I'm ready to go.
Always nice to learn somehting new.
"That government is
themselves."
Thomas Jefferson
Let's find out how we can make a new prop (object) from an existing object ... next ...
Click on the Grouping Tool to open ...
... continued on Page 2 ...
cheers,
dr geep ... :o]
edited 10/5/2019
The Group Editor (GE) has many different functions but we're only going to use a couple of them here to make a "NewProp."
Make sure you have the GROUND selected and let's make a new prop from the GROUND.
We are going to duplicate Poser's GROUND prop ... next ...
cheers,
dr geep ... :o]
edited 10/5/2019
1a. We can name it "NewGroup so let's just CLICK "OK"
Now, we want to include "All" of the polygons in the GROUND so let's ...
All of the polygons (squares) in the GROUND should appear RED which means that they are selected and will be included in the "NewGroup."
3a. Let's just call it "NewProp" for now so CLICK the "OK" button to complete the operation.
Now we can close the GE by clicking the small square in the upper right hand corner or just select a different Editing Tool.
Next ... using our "NewProp" ...
cheers,
dr geep ... :o]
edited 10/5/2019
BUT <------------- and this is a BIG one ...
The "NewProp" parameters will be set to the default values ...
That is, 100% for all the Scale parameters (x, y, and z) ...
All rotations will be 0 (zero) ...
All Tran values will be 0.000.
Now, the (unrendered (ground) shadows)) are hiding our "NewProp" so let's turn them off and try a render to see what happens ...
cheers,
dr geep ... :o]
edited 10/5/2019
See the "Shadow_Catch_Only" parameter ... it's checked, isn't it?
That means the "NewProp" <---- let's just call it NP, ok? Ok.
That means that the NP will only catch shadows of other props and figures in the studio.
(just like the GROUND prop)
Try adding a prop and/or figure and render again ... Ah HA !!! It's just like the GROUND.
First ... You did make the GROUND invisible, didn't you? :blink: ___HUH?
Select the GROUND and under "Properties" ... UNcheck the "Visible" parameter.
After we UNcheck "Shadow_Catch_Only" parameter for the NP and render, we can see our NP ...
Walla!!! ... there it is.
Let's UNcheck the "Shadow_Catch_Only" parameter before we continue back in the ...
... Pose Room ... .................. Next ... where is the NP? ...... Exactly? (the yTran parameter ???)
Remember waaaaaay back when ... we said the GROUND is not on the Floor (yTran 0.000)?
Now, we can prove it ... next ...
cheers,
dr geep ... :o]
edited 10/5/2019
Use the [menu] "Figure" >>> **"Drop to Floor" ** (Ctrl+D) ...
... and see what value we have for the yTran parameter.
If we see yTran 0.103* then we may have our Display Units set to inches ...?
If we see yTran 0.009* then we may have our Display Units set to feet ...?
If we see yTran 2.621* then we may have our Display Units set to Millimeters ...?
If we see yTran 0.262* then we may have our Display Units set to Centimeters ...?
If we see yTran 0.003* then we may have our Display Units set to Meters ...?
** this value may be different for different versions of Poser, e.g., if not using Poser 6*
BUT ...
If we see 0.001 then we are using Poser native units. <<<< This is what we want to use.
Hmmm ... yTran = 0.001 ??? What does this prove?
Note - Previous winners are not eligible.
Anyone ??? ![]()
cheers,
dr geep ... :o]
edited 10/5/2019
Stop the presses !!!!!!!!!!!!
**>>> ahudson <<<
Please email your snailmail address to:
"geep(at)cableone(dot)net:
to have your prize sent to you.
****Note - replace the (at) with @ and the (dot) with a . for the correct email addy
Congratulations and ...
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Now, for a bonus prize ...
How far (using DGS) below the "Floor" was our NP BEFORE we did a "Drop to Floor?"
What would the Real World distance be?
Anyone ??? ![]()
cheers,
dr geep ... :o]
edited 10/5/2019
Considering that we used The Ground to create the NewProp and the Ground is -0.001 below the Floor, wouldn't the NewProp also be that same NPU = -0.001 below the Floor?
If I did this correctly
PNU 0.001 x 1000 = 1.0 PNUs
In 0.103 x 1000 = 103 In
Ft 0.009 x 1000 = 9.0 Ft
MM 2.621 x 1000 = 2621 MM
CM 0.262 x 1000 = 262 CM
MTR 0.003 x 1000 = 2.0 Mtrs
Quote - Now, for a bonus prize ...
Note - Previous winners are not eligible.Anyone ???
"That government is
themselves."
Thomas Jefferson
Oops, sorry if I did not make the question clear ...
The question is:
How far** (using DGS) below the "Floor" was our NP BEFORE we did a "Drop to Floor?"
(in other words)
How far (in Real World Unit measurements) did the NP move when we did a "Drop to Floor?"
(or in other words)
How far did the NP move from it's original position?
Remember that Poser's "Floor" is ALWAYS at yTran = 0.000 !!!
(as in "Drop to Floor")
cheers,
dr geep ... :o]
edited 10/5/2019
It moved Up 0.001 NPUs or
In 0.103 Up
Ft 0.009 Up
MM 2.621 Up
CM 0.262 Up
MTR 0.003 Up
The Values Poser show, when you change the Units Used.
Quote - Oops, sorry if I did not make the question clear ...
The question is:
(in other words)
(or in other words)
How far did the NP move from it's original position?Remember that Poser's "Floor" is ALWAYS at yTran = 0.000 !!!
"That government is
themselves."
Thomas Jefferson
Quote - Uh oh ... where did it go and why doesn't it render?
I would guess because it has no materials attached to itself. It was created as a wireframe prop so it would render as an invisible (Does that makes sense?)
Hi Folks,
Dr Geep here ...
Would you like to learn how to ***use Poser's GROUND prop ... ***
... to accurately scale the size of objects and figures in the studio? :blink:
... to determine distance between objects and figures? :blink:
... to make new props? ... even make background props? :blink:
... to see how Poser's Magnet and Wave deformers work? :blink:
... to find out how DGS works? :blink: ___ DGS ???
... to maybe do other "magic" things that (even) I have not thought of yet? (ha ha) :blink:
Well, would you? ...
What would you pay for this class? - $3.00? - $2.00? - $1.00? - $0.00? ...
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
