Fri, Nov 22, 11:38 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Pine Forest
sparrownightmare ( ) posted Mon, 03 November 2008 at 5:58 PM · edited Fri, 22 November 2024 at 11:38 PM
Hi.
I am trying something a bit out of my ordinary subject matter and I would like to know if anyone can point me to any free sources of info on using the replicator object to create a realistic looking pine forest on a hilly slope?  The basic replicator info is a bit simplistic.  I am having issues making it appear smooth and random enough.  Any help appreciated.
Rich
bwtr ( ) posted Mon, 03 November 2008 at 6:42 PM
Are you using the "Surface" Replicator?
Have you brought the Hot Point on the tree to be used down to the bottom, and located it at the appropriate level on the "hill"?
Can you show a screen grab of your problem please.
Brian
bwtr
bwtr ( ) posted Mon, 03 November 2008 at 6:59 PM
Is this of any help? Brian
bwtr
And
bwtr
bwtr ( ) posted Mon, 03 November 2008 at 7:00 PM
And
bwtr
sparrownightmare ( ) posted Mon, 03 November 2008 at 7:57 PM
That's roughly what I am trying to do. Could you send me a bigger screenshot?  I can't see the settings.  And no I am bringing in a replicator object and adding 1 tree to it.  Thanks for the help.
bwtr ( ) posted Mon, 03 November 2008 at 8:13 PM
Gee whiz--are you say you are NOT using the SURFACE Replicator?
Losing me I am afraid!
I don't think I should need to do closer screen grabs!
Look at the area at which I have directed the arrows and think!
Brian
bwtr
sparrownightmare ( ) posted Mon, 03 November 2008 at 8:29 PM
I tried to look at them, but the images aren't clear enough for me to make out.  I run at 1680x105 resolution so images can be hard to read at 800x500.  I see what areas you have put arrows in so I will try and figure it out.  I have never had to use this tool before.  Most of my models are scifi and very few terrain.  Thanks for the help anyway.  Could you tell me the difference between using the surface replicator and a regular replicator object?
bwtr ( ) posted Mon, 03 November 2008 at 9:14 PM
Carrara Help/Manual---P351-353
And, you may want to buy Marks Tutes,, see the list under "Using the Replicators" on this page
http://www.markbremmer.com/3Bpages/carrara6Pro.html
Brian
bwtr
sparrownightmare ( ) posted Tue, 04 November 2008 at 7:11 AM
Thanks for the info, I will check them out. :)
