Thu, Dec 26, 6:51 AM CST
Subject: Restarting an Animation Render
dphoadley ( ) posted Mon, 03 November 2008 at 2:45 AM · edited Thu, 21 November 2024 at 4:48 PM
I'm rendering a 999 frame animation in Poser 5, each as an individual png fro assembly after completion.  At frame 176, Poser froze and refused to render.  After closing Poser, and reopening it, I can't seem to restart the render from where I left off, and Poser wants to rerender everything from the beginning.  I've tried to retime it, and to change the range on resampling Keyframes.  What must I do, as I do know that this is doable.  Any and all suggestions will be welcome.
DPH
Adom ( ) posted Mon, 03 November 2008 at 2:53 AM
Don't know about p5 but in p7 there is a "time span" option in "movie settings" window where you can set  the range for output animation (start frame and end frame).
dphoadley ( ) posted Mon, 03 November 2008 at 4:05 AM
I did find a way, but it was by altering the time sequence, rather than the frame range as in 3ds Max, etc.  Much more trickier.
DPH
DSQRD ( ) posted Thu, 06 November 2008 at 10:53 AM
from the image pallette set the slider to frame 177, then from the animation menu hit make movie, set sequence type to :image files" and press start
shuy ( ) posted Fri, 07 November 2008 at 3:59 AM
This is P7 but I'm almost sure that in P5 was very similar. As I remember you have acces to this window from "make movie" and "render setting".
