Sat, Jan 25, 2:30 PM CST
Renderosity Forums / The MarketPlace Wishing Well
Welcome to the The MarketPlace Wishing Well Forum
Forum Moderators: Staff
The MarketPlace Wishing Well F.A.Q (Last Updated: 2025 Jan 19 6:06 am)
Have an idea for a MarketPlace product? Would you like to let the MarketPlace Merchants know?
This is the place!
Make sure you check The Product Showcase Forum and The Product Showcase Art Gallery.
Subject: Something I would like to see and desperately need...
Doran ( ) posted Fri, 07 November 2008 at 8:07 AM · edited Sat, 25 January 2025 at 1:30 PM
I posted this in the Poser Forum as well. I probably should have posted it here first, though.
With my runtime folder being the size that it is, it would be quite the task to go and eliminate all of the old .bum references and maps individually. The problem is that I have been using Poser from 4 to 7 and my external runtime folder still has a lot of old references. Is there a python script or an application that batches out the work? I WOULD PAY GOOD MONEY FOR SUCH A THING! A lot of money! Stupid amounts of cash to solve this issue.
So far all I have been doing is, when a reference would appear in a new scene, I would deal with it on a project-by-project basis. The problem is that there seems to be no end doing it this way. Reinstalling each item one by one isn't an option for me. To do so would take time I don't have and keep me from my work. And using Notepad to change line references takes an exhaustingly long time per file. I tell you, the person who releases a product to address this issue will get my dollars fast. What a headache. It makes me wish I had begun with Poser pro instead.
markschum ( ) posted Fri, 07 November 2008 at 3:59 PM
the files you need to edit are text files unless you use the compressed format.   There are several text editors that will search and replace across multiple files .
try textcrawler or blockreplacer.
http://www.pejman.com/
http://www.techmalaya.com/2008/03/18/replace-text-multiple-files/
I would make sure you have a backup before doing this .
ockham ( ) posted Sat, 08 November 2008 at 6:01 PM
Ditto.  TextCrawler (the second link) works very nicely and fast.  The other
one requires a Java runtime, which you may not have already.
Tell TextCrawler to start in one of your runtimes, as in F:Poser 7Runtime, and it will
find and replace quickly.  One caution from painful experience:
Be sure to add the dot, as in
Find:  .bum
Replace with:  .jpg
Otherwise you'll be replacing every
        bumpStrength 1
with
        jpgpStrength 1
and replacing every
        bumpMap NO_MAP
with
        jpgpMap NO_MAP
My python page
My ShareCG freebies
ockham ( ) posted Sat, 08 November 2008 at 6:08 PM · edited Sat, 08 November 2008 at 6:08 PM
I thought about doing this in Python, but there wouldn't be any real advantage.
Python file operations are comparatively slow.  The only thing the Python could do
better is to locate all of your connected runtimes automatically.
My python page
My ShareCG freebies
Doran ( ) posted Sun, 09 November 2008 at 10:19 PM
Thanks Guy :)  BTW I love the animation, ockham. What is she doing exactly?
muralist ( ) posted Wed, 12 November 2008 at 10:29 PM
CRPro at Hogsoft.com works great for fixing references and cleaning Runtimes.
Doran ( ) posted Wed, 12 November 2008 at 10:33 PM
Hogsoft.com is gone. Links don't work. The page is no longer available.
muralist ( ) posted Wed, 12 November 2008 at 10:47 PM
muralist ( ) posted Wed, 12 November 2008 at 10:48 PM
It also might be for sale here at Renderosity.
markschum ( ) posted Wed, 12 November 2008 at 11:03 PM
theres a free copy of Correct Reference , only works on textures though. I am not convinced thaat it will do what you need but it was in freestuff here.
