DAZ|Studio F.A.Q (Last Updated: 2025 Feb 17 12:11 pm)
Have you recently upgraded DS, and if so from which version? It's been a while since the version of 3delight changed, but if you are making a big enough jump (to a current version) you may need to reset your pwGhost download from your DAZ order history to get a working version.
Otherwise, check the log file and makle sure you haven't inadvertently moved any files in the Studio folder or its subfolders (other than Content) around. Also make sure you are using the 3Delight renderer, not one of the OpenGL modes.
I hve been using pwghost without having any trouble, when i go to use it now it renders it black, is there a setting somewhere that has to be set to keep it from turning everything black. Thanks
