Forum Moderators: Staff
Alright, here it is, working on some final things (or so I thought) with this figure as far as JPs go. And now that I'm doing adjustments on the scales I noted that I can't get them to work correctly around the chest. Regardless of what I do with the scales when I reload the CR2, after saving a fresh Cr2 even, the new JP scale settings are gone and default to worthless settings. This is occuring on the collars and chest. So as is if I scale his chest in almost any direction his chest either explodes or implodes into a tangled mess. Have some screen shots if needed posted. It doesn't appear to be losing the '.'. It will even do this in mid corrections. I correct the chest's "Yscale" of one of the collars. Then fix a collar and go back to the chest and it defaults to the junk position again. The chest is acting as the hip on this figure, and there are 4 limbs attached. Now if it comes to having to make another body part the hip or hacking the cr2... anything, just point me in the right direction. Thanks.
