Gill,
i dont claim to know even half as much as you gurus...
but what if all the objects are coming in with display mode set to "filled box"?
look under object --- display options and see what things are set at. this is the only place ive found where you can end up with a box instead of the actual shape. (btw, i have pro studio 6)
if this doesnt work... well... ummm... am keeping my fingers crossed for you!
=D
Rarer than a hairy egg and madder than a box of frogs....
< o > < o > You've been
VUED! < o > < o >
O
O
Thanks for the tip melikia but all objects are set to display smooth shaded.
I have narrowed it down to only happening with terrains. I can have as many ojbects and plants in a scene as I want and all display right. Load a terrain....fine too - even if I select one of the other objects in the scene. BUT - load a SECOND terrain and the first terrain reverts to a box in all 4 views.
Gill
It's not the red terrain that's the problem - that's just the mesh showing. My problem is that dark flat box on the right - should also be a terrain mesh
Bruno, I can't check right now as I have a render going. Something I started yesterday in 6 and I'm renndering it in 7 but I will check when it's done (that could be tonight or tomorrow morning 'pending on how long the render takes
Gill
Right....
So very weird this - after my render had finished I started a blank scene and then checked the open gl software option and also unchecked the anti aliasings.
On re open - vue crashed. 3 times. Then finally it said it'd detected conflicts and did I want to reset factory defaults. I replied yes.
Now I can load 2 terrains and they both show as meshes BUT when I add a 3rd, the 2nd goes to the flat grey box. Resources are at 75%
I'll raise a ticket tomorrow
Gill
I have had this problem too. It is a feature, not a bug :-)
Check out the Limit OpenGL polygons settings. By default in Vue 7 it is 500,000 wich is quite low. If your scene has more than this, it goes back to displaying boxes.
I have put it at 10,000,000 (with a GeForce 8800 512mb of memory).
It would be interesting to have recommended settings depending on video chips and memory.
Fantasy pictures,
free 3d models, 3d tutorials
and
seamless textures on Virtual Lands.
Quote - but if I hid a few from display the ones I was working with looked ok again.
Thanks Gill for that lil tip. I will try it with Fonts as they throw splashes colors around my scenes to the point I can not see what I am doing!!!
I would rather
be Politically Incorrect,
Then have Politically
Correct-Incorrectness!!!
Quote - > Quote - but if I hid a few from display the ones I was working with looked ok again.
I find the best way is to create a new layer and turn off visiblity, and when you've finished needing to see a plant or object, drag it into that layer. Many of my scenes contain a layer called 'hidden plants' !!!
Gill
Mazak
This is OpenGL preview!
Thanks for this tip - I turned off the limit OpenGL polygons and now things display much better!
LVS - Where Learning is Fun!
Cool cuz I'll tell ya folks I have this very same problem going on in Vue 6 inf. Many of the objects I have in the scene does this too. I know I have enough ram (8GB) and I am on a quad core machine with Vista 64. Many times this happens when I am moving and object into place or move the cameras.
Oh yeah and a 9600GT vid card 512MB
Thanks for the tip of unchecking the box. I kept adding terrains to see what would happen and on the third one, the box. I had set my polys to 500,000. Now all Ok.
But I have a question. When I looked at Gill's picture of the terrain in 6 and 7, mine looked the same re: the red "selection mesh." Can one change the one in Vue 7 I to reflect the spacing of the mesh in Vue 6 I? I have tried resizing and a lot of other things. I don't like the dense quality of it. I find it distracting.
I can't find anything in 'options' and I've looked in the manual but no luck.
This is horrid and I can't line anything up properly.
Anyone know how to get it to show the unselected objects properly ??
Gill
