Thu, Nov 7, 11:36 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 07 11:22 am)
Subject: How to make something Invisible/transparent?
Nosiferret ( ) posted Sun, 30 November 2008 at 11:17 PM · edited Thu, 07 November 2024 at 11:28 AM
There is no way to check mark the "Visible" portion on the item, but the item is broken down in the Materials room. I can make the item say a hair ribbon appear transparent but it appears as a shadow. I don't want it to show up, is there a way for me to do that in the Materials room?
Cage ( ) posted Sun, 30 November 2008 at 11:31 PM
To make something fully transparent in the materials room, set Transparency and  Transparency_Edge to 1.0.  Set Transparency_Falloff to 0.0.  Set the specularity to 0.0.  A completely transparent material should not cast any shadows.
Nosiferret ( ) posted Sun, 30 November 2008 at 11:57 PM
Yay! Thanks Cage! It worked :)
IsaoShi ( ) posted Mon, 01 December 2008 at 4:00 AM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3231222
Just one little point to note though...
If you use AO in your scene, even a fully "transparent" material may still give some occlusion on nearby surfaces, as seen in the attached thread "Not quite invisibles".
To prevent this, you also have to check "Invisible to raytracing" for the transparent object.
Cage ( ) posted Mon, 01 December 2008 at 1:45 PM
Ooh.  I didn't know that, IsaoShi!  Good information!  This is why I love this place!  :D  :D  :D  :woot:
The AO problem would explain some rendering oddities I've been seeing in my own efforts.  Hmm.
